Old Oct 14, 2010, 01:00 PM
Warthog_Fan is offline
Find More Posts by Warthog_Fan
United States, NY, Endicott
Joined Jun 2006
Source for Carbon Fiber, Aluminum, and Cardboard Tubes
Guys,
I'm going to build a vintage kit of an aerobatic biplane that was designed in 1973. The wing span is 55". As with many larger wings of this time period, they are built in two halves, and then glued together in the center. Then you have to add a 4" wide strip of fiberglass or polyester tape over the center section to give it adequate strength.
I don't want to use the tape. I'd like to use carbon fiber or aluminum tubes in the wings as spars, kind of like the newer ARFs do that have larger wings. This makes for a neater covering job without the bulge of the tape on the center section. It also would allow me to take the two wing halves apart for easier transportation.
Does anyone know of a source for the carbon fiber and aluminum tubes, and also the cardboard or fiber tubes that are permanently installed in the wing panels to receive the spar tubes?
Thanks in advance.
Bob
Warthog_Fan is offline Find More Posts by Warthog_Fan
Old Oct 14, 2010, 04:24 PM
Brian76239 is offline
Find More Posts by Brian76239
Brian76239's Avatar
Nashua, NH
Joined Nov 2008
Take a look at McMaster-Carr
I have used this place as a source for years.
www.McMaster-Carr.com
Another place for finding certain items is www.smallparts.com
They both stock lots of items that you just can't find at the local
hobby shop. The downside - They are Industrial supply houses.
The shortest length of tubing is usually 6 ft.
The tubing is shipped inside a large cardboard tube.
That can get expensive.
Brian76239 is offline Find More Posts by Brian76239
Sold CX2 carbon fiber and aluminum Fastleft Aircraft - Electric - Helis (FS/W) 1 Oct 09, 2010 05:11 PM
Found Carbon Fiber tubes 196 OD x .121 ID x 24 wbrannies Aircraft - General - Miscellaneous (FS/W) 5 Sep 24, 2010 10:47 PM
Discussion Carbon Fiber Rods/Tubes rr9434 Coaxial Helicopters 3 Aug 31, 2010 10:54 PM
Need a good source for carbon fiber tubes gunnisonflyer Vendor Talk 3 Dec 01, 2003 11:06 AM
WTB/ Source for 1/8 carbon fiber tubes for fanfold 3d's pval3 Aircraft - Electric - Airplanes (FS/W) 9 Nov 15, 2003 04:45 PM
