Old Apr 13, 2012, 11:15 AM
aviator4934's Avatar
United States, VT, Warren
Joined Apr 2011
Adapters... direct or wired better?
Which type of battery adapters are more reliable, or considered "better"? An adapter that has wires inbetween the two connectors, or one that is "directly" connected with no wires?
aviator4934 is offline Find More Posts by aviator4934
Old Apr 13, 2012, 01:23 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Whichever one works and is on hand. IMO, it don't matter unless it matters to the user. Tight on space? No wires. Have space or need distance, wires...
Rick
rampman is offline Find More Posts by rampman
Latest blog entry: mean well S-210-12 power supply
Old Apr 13, 2012, 01:40 PM
Hey, watch this!
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I'm not following, are you asking if you are losing anything by using a connector on your charger that has an adapter attached vs a hardwired connection from the charger to the plug?
There should be little to no voltage drop across the connection.
dedStik is offline Find More Posts by dedStik
Old Apr 13, 2012, 11:20 PM
United States, NJ, Lodi
Joined Jan 2012
From a reliability standpoint it depends on the quality of the product. I have some straight connectors that are rock solid and have had others that the solder would just bend from push/pull on them whereas ones with wires in between the wires take the flexing and the push/pull never really stresses the joints. Space is the other issue typically.
Syner01 is offline Find More Posts by Syner01
Discussion What's better: Direct-Drive Tail Rotor or Motor indiggio Electric Heli Talk 3 Feb 17, 2012 02:15 PM
For Sale DX5E for your wired or wireless xb360 controller with windows adapter ghtscorexception Aircraft - General - Radio Equipment (FS/W) 1 Dec 25, 2011 09:06 AM
Discussion ESC Wire Length - Better to extend motor wires? nioa Castle Creations 0 Dec 16, 2011 03:40 AM
Question Which is better? Short battery wire or short motor wire? shschon Power Systems 1 Dec 31, 2005 07:02 AM
Is It Better A Direct Drive Or Outrunner Or A Geared Brushless Motor ? agapornis Power Systems 9 May 19, 2005 04:19 PM
