Old Feb 14, 2012, 05:34 PM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Originally Posted by Dangaras View Post
Ok, on issue is the nose wheel wires tangling in the wheel when in the retract position. Some have told me about using springs or rubber bands to pull back the wires but I have not seen a suitable implementation.
I struggled with the same issue, I used springs and steering was really bad. I ended up just running the wires through tubing and route the tubing with cross members added to the frame.
If you want pics, I can get some later.
mattyhawk is offline Find More Posts by mattyhawk
Old Feb 14, 2012, 05:43 PM
Dangaras is offline
Find More Posts by Dangaras
Dont be divided from the truth
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
That would be much appreciated..
Dangaras is offline Find More Posts by Dangaras
Old Feb 14, 2012, 06:36 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
I also considered doing this method. If I had to do it again, I would probably try the method in the picture.
I'll get pics of mine tonight
Old Feb 15, 2012, 01:45 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
A-26 Landing lights test
So here is a vid of the landing lights cycling with a servo tester..
VQ A-26 Landing Lights - Test (1 min 6 sec)
Old Feb 15, 2012, 09:19 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Very cool!
Whats that noise when they are coming down?
TripleW is offline Find More Posts by TripleW
Old Feb 15, 2012, 09:22 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Originally Posted by TripleW View Post
Very cool!
I think the battery for the servo tester is low.... Caused the servo rate reducer to stumble..
Old Feb 19, 2012, 11:59 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Wow, that is very cool!
Old Feb 20, 2012, 12:05 AM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Sorry, forgot to get this posted for you Dangaras. Yes, i know it looks nasty in there. I gotta work on cleaning up the paint job.
Old Feb 20, 2012, 09:54 AM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Allrighty then. From what I can see you constrained the nose wires in some plastic sleeving, kind of like golden rod.
Are the wires tight when the wheels are deployed? I could not stand the slop in the steering when I first assembled mine so I redid them with the wires pretty snug.
I would redo them using your idea. I bought some trike e-retracts off the HK site that handle 17.5lb aircraft. I have a pair that look exactly the same for my H9 corsair that were made by RC Lander. I will wait for them to arrive...
The lights are mounted and look good in the model. However, I have to still mess around with tx endpoints, servo linkages etc to get them 100%.
Old Feb 20, 2012, 10:59 AM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
the wires go slack when retracted and are pretty tight when locked. Since I use spring air retracts, I struggle with keeping the wire tight, but not too tight or the retracts wont lock. When you mount the HK retracts, I would be interested to see how they turn out.
Old Jul 21, 2012, 07:13 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
Well I got the electric retracts installed and they work great! Until the curved section of the oleo thsat holds the wheel fell off and dragged the tip through the dirt. A large-small combination gear inside the retract separated and the retract will not cycle under load. See pix.
The US reseller has not responded to my query for help so far.
On another note I had a motor throw a magnet on the last takeoff. I got her level but the trees broke her fall. Now I have some repair work to fix a leading edge and the wing panel tube socket.
Now I need to ask if anyone who has lost an invader still has any spare parts? I need a wing tube and I can't find any up here.
Old Jul 22, 2012, 08:19 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
What size is the wing tube? Maybe you could use a carbon one.
Old Jul 22, 2012, 04:29 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
It is 19.5mm (3/4") outside diameter and 16.5mm inside diameter. I cant find carbon tubes thst size and oh, the cost. I am also worried that carbon tubes are super strong, then the snap!
Old Jul 22, 2012, 06:21 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Aircaft Spruce has some 3/4 od 6061T6. It's .065 wall thickness.
http://www.aircraftspruce.com/catalo...ube_6061t6.php
Old Jul 22, 2012, 07:46 PM
Dangaras is offline
Dangaras's Avatar
Canada, ON, Toronto
Joined Mar 2010
That's funny, I found the same site about an hour after my last post! All I have to do is figure out my wall thickness and a 3/4 in tube will do. That is and a $15 min order plus shipping.
New Product ASM Giant, 92 inch, A-26 Invader-New From Hobby People SCALEFAN Glow to Electric Conversions 19 Mar 12, 2015 12:47 AM
PSS A-26 Invader Project ericm Slope 97 Sep 07, 2005 08:51 PM
Douglas A-26 Invader Delta 1 Fuel Warbirds 1 Oct 12, 2004 07:50 PM
Looking for an A-26 Invader builder. ladyliberty Fuel Warbirds 11 Sep 21, 2004 10:58 PM
ARF A-26 Invader RTaylor Scale Kit/Scratch Built 10 May 08, 2002 10:12 PM
