Old Nov 12, 2015, 07:49 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Spektrum 2014 DX6 vs. DX7 Gen. 2
I am looking to buy a new transmitter to replace my DX6i and am looking at the Spektrum 2014 DX6 and DX7 Gen. 2. Other than the additional channel and lithium ion battery, are there any other real differences between these two radios? From all the reading I have done, my impression other than the differences mentioned, is that the radios are essentially identical. Am I missing something?
Aeronca
aeronca is offline Find More Posts by aeronca
Old Nov 12, 2015, 08:59 AM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Spektrum Transmitter Comparison Chart
2 & 3 position switch amounts
Rotary Knob
Servo balancing
Adjustable Servo Speed
Programmable Mixes & Curve Mixing
Additional Wing Type
Additional Tail Type
If any of these matter to you then the DX7gen.2 would be your option.
freechip is online now Find More Posts by freechip
Old Nov 12, 2015, 10:04 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
Rotary Knob
Servo balancing
Thanks, freechip! GREAT comparison chart for most all the Spektrum radios (by the way, where did you find it?). Now to weigh the differences and make a decision.
Aeronca
Old Nov 12, 2015, 10:23 AM
freechip's Avatar
Joined Aug 2008
Originally Posted by aeronca View Post
Thanks, freechip! ...snip... , where did you find it?). ...snip... Aeronca
Found it like this... Click
Old Nov 12, 2015, 10:28 AM
freechip's Avatar
Joined Aug 2008
...snip... Now to weigh the differences and make a decision.
I often recommend folks it's not about the channels but about what the higher channel transmitters have to offer in programming. Some of the things I listed for you as differences for me have now become a MUST HAVE so my choice when deciding between the 6 vs 7 would be a no brainer.
Good luck with your decision and if you have more ???? feel free to ask them, I own both the 6 & 7 along with the others so I may be able to help you more if you need/want it.
Old Nov 14, 2015, 08:13 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Go for the DX9. Everything you will ever need plus double antennas for diversity.
And an integrated charger that does not suck the battery dry like the DX6/DX7 LiPo pack could do.
Mukenukem is offline Find More Posts by Mukenukem
Old Nov 14, 2015, 09:18 AM
freechip's Avatar
Joined Aug 2008
The pack I'm using in my DX6 & 7 doesn't get sucked dry... I'm not using the pack with built in charger
Old Nov 14, 2015, 09:56 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
What pack are you using, freechip?
Aeronca
Old Nov 14, 2015, 11:15 AM
freechip's Avatar
Joined Aug 2008
2s2,000mAh LiIon transmitter pack and use this charge adapter to charge it on my main charger.
Old Nov 14, 2015, 02:52 PM
Frank Hurd is offline
Find More Posts by Frank Hurd
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
Freechip-
Great solution. I removed the battery from the DX6 box and I am using the battery like you are doing. No more self discharging!
Frank
Frank Hurd is offline Find More Posts by Frank Hurd
Found Looking for a current gen Spektrum DX6, DX7 or DX6i LehmanCM Aircraft - Electric - Multirotor (FS/W) 0 Aug 15, 2015 09:40 PM
Sold Spektrum DX6 (2014) helicycle Aircraft - General - Radio Equipment (FS/W) 3 Jun 02, 2015 02:38 AM
Sold Spektrum DX6 (2014 version) with Case kelchm Aircraft - General - Radio Equipment (FS/W) 3 May 15, 2015 06:24 PM
Question SPEKTRUM DX6 vs DX7 Question... calofr Radios 34 Aug 15, 2009 10:00 AM
Discussion Spektrum: dx6 vs dx7, which is a better deal? dj_d Radios 25 Dec 15, 2008 03:33 AM
