Old Oct 23, 2013, 05:16 PM
RainyDayRC is offline
Find More Posts by RainyDayRC
TEAM CIRRUS FPV
RainyDayRC's Avatar
United States, WA, Seattle
Joined Oct 2013
Best Sub $50 Scratchbuilt Combat Plane (Dollar Tree Foamboard)
I need a plane that is cheap, durable, and builds easily repairable for streamer and full-contact combat. It would be nice if it could be powered by a 2200 3s lipo as I have a TON of them. Also, I primarily use Dollar Tree Foamboard for scratchbuilding. Any suggestions?
RainyDayRC is offline Find More Posts by RainyDayRC
Old Oct 24, 2013, 05:08 PM
newguy2012 is offline
Find More Posts by newguy2012
Using foam in moderation
newguy2012's Avatar
United States, IL, Aviston
Joined Sep 2012
http://www.rcgroups.com/forums/showthread.php?t=1542672
Finishing mine tonight. It has quite a few fans, good luck!
newguy2012 is offline Find More Posts by newguy2012
Old Oct 24, 2013, 05:41 PM
TEAM CIRRUS FPV
RainyDayRC's Avatar
Joined Oct 2013
Thanks, good luck on the maiden!
Old Oct 26, 2013, 12:36 PM
WombatControl is offline
Find More Posts by WombatControl
WombatControl's Avatar
Joined Jul 2011
The SEMFF Stingray is a great design.
You also can't go wrong with any flying wing design. The FT Versa Wing is a great design, although you can use just about any one of the many wing designs on this forum. For a smaller wing, I love the Dead Simple Wing (24 inch wingspan).
I've done combat with the Funbat/FT Bloody Wonder. It's a great design and flies really, really well.
WombatControl is offline Find More Posts by WombatControl
Old Oct 26, 2013, 01:15 PM
TEAM CIRRUS FPV
RainyDayRC's Avatar
Joined Oct 2013
I've built 3-4 Versa wings before with different power systems, from a slow setup as a beater, to a screaming fast setup that hauls at nearly 90 mph! I was just looking for something different to fly combat with against my friends and might just get some "on a budget" electronics for a Versa or KF flying wing.
Old Oct 27, 2013, 07:53 PM
Redcoat is online now
Find More Posts by Redcoat
Southern Ontario
Joined Nov 2010
Try the Funbat...
http://www.rcgroups.com/forums/showt...ghlight=funbat
Lots of flyers in my area are buiding & using them.
Redcoat is online now Find More Posts by Redcoat
Old Oct 28, 2013, 06:30 PM
newguy2012's Avatar
Joined Sep 2012
The stingray is badass! Build it to spec and you will love it!
Old May 03, 2014, 04:44 PM
timwhoa is offline
Find More Posts by timwhoa
Foamy Fan
United States, OR, Portland
Joined Nov 2012
I like the kesl wing, replace the epp with doubled up dollar tree foam , paper on or paper off, i did paper off 6 layers thick on the front, the covered it with packing tape after painting, I put a 5/16 inch wood dowel in the front leading edge full length, and a 5/16 square "dowel" across the motor mount to form a triangle of strenght inside the foam, the dowels are sold at home depot for .48 cents each in the lumber area, so the entire airframe is 8 bucks for 6 sheets of foam and 2 dowels, here is a link for the kesl, on this page post 73 and you see the 2 i have built so far
http://www.rcgroups.com/forums/showt...040837&page=73
timwhoa is offline Find More Posts by timwhoa
Old May 04, 2014, 03:09 PM
vastsky is offline
Find More Posts by vastsky
Professional amature
Canada, BC, Kamloops
Joined Oct 2011
StingRay 3.0
You may need to play with the CG if you wish to use heavier 2200mAh as it is designed around a 1300mAh 3S.
Great agile FAST plane!
vastsky is offline Find More Posts by vastsky
Old May 04, 2014, 09:56 PM
timwhoa is offline
Foamy Fan
Joined Nov 2012
also the Dekan f22 can be built out of a single piece of dollar tree foam, so only 1 dollar gets you in the air, i build one with no spars and no carbon, just cut the foam, hot glue the fins and under rails, mount the rc gear with velcro and your UP and rockin
http://www.rcgroups.com/forums/showthread.php?t=740049
Discussion Dollar Tree Foamboard in the UK AmyW Foamies (Scratchbuilt) 12 Aug 14, 2015 03:16 AM
Discussion Dollar tree foamboard? hayabusa Foamies (Scratchbuilt) 457 Dec 08, 2014 02:12 AM
Yippee! KFm-4 Delta | My First Dollar Tree Scratchbuilt fnffishcore Foamies (Scratchbuilt) 3 Mar 20, 2014 04:27 AM
Discussion Scratchbuilt Dollar Tree "Road Runner" bjc4073 Foamies (Scratchbuilt) 2 Oct 01, 2013 10:50 PM
Discussion My Dollar Tree Foamboard 50% Sized "Mini Apprentice" NFA Fabrication Foamies (Scratchbuilt) 1 Apr 23, 2012 04:01 PM
