Old Sep 22, 2013, 02:17 PM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
Reasonable attempt at the tricky area ? (see photo in post#2)
stegla is offline Find More Posts by stegla
Old Sep 27, 2013, 06:39 AM
Cap_n_Dave is offline
Find More Posts by Cap_n_Dave
Joined Mar 2008
Stegla:
Are you aware of Dave Rees' Tunnan for EDF FF?
Nice build!
-Dave
Cap_n_Dave is offline Find More Posts by Cap_n_Dave
Old Sep 28, 2013, 04:03 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Thanks for the post, I was not aware of that Tunnan. There is a nice Tunnan for Rapier on Mike Stuarts site http://www.ffscale.co.uk/plans3.htm
There has been progress on mine with the fuselage having been tissued and doped. Getting a bit worried about weight however, the target AUW of 150g would give a wing loading of 25g/dM^2.......... don't really want to get above 30g/dM^2 so 170g should be ok!
Steve
Old Sep 29, 2013, 05:50 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
There is a snag, namely, the cg is too far aft and the last thing this flying lumberyard needs is noseweight
Shall move the fan unit to under the cockpit............ shame because I spent a lot of time getting nice smooth ducting.
Steve
Old Sep 29, 2013, 04:38 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
It looks like the Rapier powered Tunnan doesn't have a duct. Everything behind the engine is wide open. It may not be as pretty, but its probably more efficient.
Trisquire is offline Find More Posts by Trisquire
Old Sep 30, 2013, 03:07 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
The Tunnan duct is pretty efficient for EDF. Efficiency is not quite the issue for F/F compared to R/C, however, a nice efficient setup is kinder to the gear and chances of success are greater.
From past experience I don't anticipate needing more than 2/3 throttle to power the new Tunnan.
Steve
Old Oct 12, 2013, 05:05 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
It has been flying weather recently...........so not much building.
Nevertheless, there has been a little progress with the 'flying lumberyard'
Steve.
Old Oct 15, 2013, 02:05 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Vac-formed the canopy using a home-made vac-former
Here's a link to the vac-former thread............
http://www.rcgroups.com/forums/showthread.php?t=1672236
The plug is balsa covered with 1oz glass.
Steve
Old Oct 23, 2013, 05:48 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
More progress. Toying with the idea of tissue over mylar for the surfaces...........haven't done tissue over mylar for years, maybe someone can jog my memory how it's done
Test flying will be at an AUW of about 130g. AUW with paint and detailing should hopefully be near to the target 150g
Steve
Old Oct 27, 2013, 05:25 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
The surfaces have been covered with 5 micron silver Mylar stuck with Balsaloc. Next job is to cover again with Esaki tissue.
Steve
Old Oct 29, 2013, 11:46 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Dunno if useful info: one need not do a flawless finish on a vacu form plug.
Simply do a second Canopy pull over the first one.. Neatly removes any plug surface imperfections that telegraph through.
V nice build by the way.
Bare is offline Find More Posts by Bare
Old Oct 29, 2013, 04:42 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Thanks for the tip Bare......... shall definitely try it next time as I try to avoid using epoxy where possible.
Steve
Old Nov 02, 2013, 01:32 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
I've done the surgery neccessary to move the fan-unit 4" forward. The fan-unit simply sits in the saddle and is held in with sticky-tape.
Easy access to all the gear is essential.
The timer fitted is an early prototype of the KP timer............ might as well use it! The ESC is a 10A Pentium.
The wiring has been kept as short and lightweight as possible.
Steve
Old Nov 02, 2013, 05:41 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
A downthrust vane in the exhaust.
Old Nov 06, 2013, 01:34 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
A few details added..........
A prominent dorsal aerial, wing to fuselage fillets and wing-fences.
Steve
Question DLE 20 comparison to Glow 1.20 two stroke or 1.5 FS Alcuy Engines 35 Oct 07, 2014 04:07 PM
Sold 1.4G Low Pass Filter for your 900Mgz,1.2Ghz,1.3Ghz FPV gear. $20 only one left DennyNC FPV Equipment (FS/W) 0 Aug 27, 2013 01:06 AM
Found Saito 1.20/1.25..good condition or nib crosby Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 06, 2013 10:16 AM
Wanted I need a pipe & muffler for a YS 1.20, OS 1.20, & Saito 1.20 stevster Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 04, 2010 12:45 AM
Wanted trade ys 1.20 nc for saito 1.20 - 1.50 pugstrip Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 30, 2008 05:35 AM
