Old Sep 13, 2013, 06:46 AM
3810 is online now
Find More Posts by 3810
3810's Avatar
Australia, VIC, Delacombe
Joined Nov 2003
Sagitta 600
Hello to all,
I'm about to help a friend scratch build a Sagitta 600, and was wondering if anyone has ever improved the original stab drive setup. I have built this model before and have never been able to get cable to run truly slop free.
Any ideas ?
3810
3810 is online now Find More Posts by 3810
Old Sep 13, 2013, 09:55 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
Have you tried a guitar string? I've done it on other glider's and it seem's to work fine. You need to use one of the wound string's.
prodjx is offline Find More Posts by prodjx
Old Sep 13, 2013, 02:12 PM
3810 is online now
3810's Avatar
Joined Nov 2003
Hi prodjx,I haven't tried a guitar string, I always use a bike gear cable inside the plastic tubing.
Old Sep 13, 2013, 03:08 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Yup: http://www.rcgroups.com/forums/showp...6&postcount=40
Alternatively: http://www.rcgroups.com/forums/showp...8&postcount=88
Rest of the thread:
http://www.rcgroups.com/forums/showt...itta+tip+trick
rdeis is offline Find More Posts by rdeis
Old Sep 13, 2013, 03:51 PM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
The hardest part of using a guitar string is possibility of having to ream out the ball end hole. I've also been known for using Sucess Rice perforated bag's in lieu of perforated film in a layup.
Old Sep 14, 2013, 02:26 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
I would recommend using a belcrank rather than the bent cable. There are a variety of materials you can use to keep it lite weight. You will enjoy control authority that is a million times better than the bent sullivan cable. This is especially important on elevator.
Avaldes is offline Find More Posts by Avaldes
Old Sep 14, 2013, 04:51 PM
3810 is online now
3810's Avatar
Joined Nov 2003
Thanks for all your input guys, looks like a bell crank will be the way to go.
Old Sep 14, 2013, 08:24 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I think a bellcrank is probably a good idea. However, for the lazy, it's possible to cram in a standard size servo for the elevator. In fact, my old Sagitta 600 had three standard servos. Anyway, the standard size servo may be heavy, but it can handle more friction, and I never had any trouble. I put powdered graphite inside the tube.
I have also seen a pull pull setup with kevlar string and a pulley for controlling this kind of stab. Don't remember the details except that it used a brass tube instead of a pulley. I think the tube was fixed, not rotating. Anyway, I didn't fly it but they guy who did it seemed to like it.
lincoln is offline Find More Posts by lincoln
Old Sep 16, 2013, 05:20 PM
Phoebusflyer is offline
Find More Posts by Phoebusflyer
Full Scale Better! UOHHHH!
Phoebusflyer's Avatar
United States, TX, Lytle
Joined Dec 2006
I hope there are going to be lots of pictures posted of this scratch build???!!!!!!!
Phoebusflyer is offline Find More Posts by Phoebusflyer
Old Sep 17, 2013, 01:32 AM
3810 is online now
3810's Avatar
Joined Nov 2003
I' m just helping a mate, I will see if I can talk HIM into doing one
Old Sep 17, 2013, 04:13 AM
Visper is offline
Find More Posts by Visper
Norway
Joined Jul 2008
Me also,just started on a sagitta 600 kit.Finished with rudder and elevator.May be in need for some help with the wing buildup.....
Visper is offline Find More Posts by Visper
Old Sep 19, 2013, 10:11 PM
lincoln is offline
Joined Dec 2001
My suggestions for the Sagitta 600:
-make the tail as light as you can get it
-make the fuselage at the front end of the fin a little wider than it is on the plan. It tends to break here. Alternatively, you can glue a piece of wood on the outside that runs a few inches fore and aft. Preferably sanded thin at the edges so there are no "steps" in the fuselage.
-It may help the handling to make the rear fuselage just a little longer, at least if you can keep the weight down, but then again that isn't exactly a Sagitta 600.
-extend the sheeting just a little further back on the wing. Greatly reduces covering sag.
-make the tail as light as you can get it!!
Old Sep 20, 2013, 08:21 AM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
Agree on both points. My 600/900 hybrid is an awfully sweet flying machine-- but because it uses a 900 fuse nobody notices it's not a pure 600 until I tell them. (-:
Old Sep 20, 2013, 07:48 PM
tkallev is online now
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
And take off the "balanced" portion of the rudder and make it part of the fin.
tkallev is online now Find More Posts by tkallev
Old Sep 20, 2013, 07:59 PM
3810 is online now
3810's Avatar
Joined Nov 2003
Other that taking off the balanced part of the rudder, I was going to change the air foil to a s3021.I did this to a sagitta 900 that I built about 10 years a go. The only problem I'm having is with my printer, so at the moment I can not print out the new ribs with profile. When I email the new ribs to work to print, the computer will not open them, so till I get my printer sorted, we will just have to wait.
Sold Sagitta 600 two meter Schwemmer Aircraft - Sailplanes (FS/W) 5 Aug 05, 2013 07:53 PM
Sold Airtronics NIB Sagitta Hat trick... 600, 900, XC jeffreytsanford Aircraft - Sailplanes (FS/W) 35 Jun 27, 2013 09:05 PM
Sold Sagitta 600 $150.00 pilot01 Aircraft - Sailplanes (FS/W) 1 May 17, 2013 04:13 PM
Sold Sagitta 600 Poly wing built glider--160.00 radman615 Aircraft - Sailplanes (FS/W) 3 May 02, 2013 04:54 PM
Sold Sagitta 600 from Airtronics CADILLAC200 Aircraft - Sailplanes (FS/W) 2 Mar 20, 2013 09:24 PM
