Old Oct 18, 2015, 05:52 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Last weekend at the Last Chance Aerotow I had my Blanik, which has telemetry, and it reported I detached from tow at near 1800' and within a few minutes I got into a hat sucker and went to 2606' AGL. It was a tiny speck and I bailed out of the thermal. Great flying glider.
davidjensen is offline Find More Posts by davidjensen
Old Oct 28, 2015, 02:16 PM
TeamHorizon is offline
Find More Posts by TeamHorizon
Joined Jan 2007
Originally Posted by pmccleave View Post
Guys,
I am getting ready to re-maiden my Blanik and was wondering after these have been flying for awhile what everybody has settled in on for CG. I have gone through the posts in this thread and have found everything from the original 20mm to 80mm. My first day of flying the plane originally only lasted two flights so I was not able to sort it out to know if I had right. I have it set right now at 75mm. Any feedback will be greatly appreciated.
Pat
In testing I went as far back as 90mm, aircraft flew ok however would not recover from a spin. C of G at 20-30mm from the LE the aircraft recovered instantly from a spin.
I know you have to ad more nose weight (4lbs approx) to reach the recommended C of G however it's is there for a reason, plus teh extra pound you save doesn't really add much to the models performance, it actually likes the weight.
You can run further back that recommended if you don't plan on doing aerobatics howevr personally I feel the forward position makes It a better handling aircraft,
C of G is like salt, add to taste however too much will hurt you :-).
TeamHorizon is offline Find More Posts by TeamHorizon
Site Sponsor
Old Oct 28, 2015, 02:25 PM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Wow, I'm amazed at the usable CG range of this sailplane. We're talking in the range of 3". Is there something about the configuration of this plane, wing plan, etc. that will tolerate such a broad range?
TIA,
Steve
SteveR is offline Find More Posts by SteveR
Old Oct 28, 2015, 02:56 PM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
I ended up moving my CG further Forward than my original setting after reading Len's comments and am somewhere around 60mm now and my plane recovers very well from a spin. I did not try any Flat or Inverted Flat Spins but did spin it on multiple occasions and it recovered very quickly. Not at all doubting what has been said above by Team Horizon just giving my two cents worth after putting my Blanik through the paces at our last Aerotow. Of course a lot of my Aerobatics look more like a Drunk Pilot Routine than real Aerobatics.
Pat
pmccleave is offline Find More Posts by pmccleave
Old Mar 25, 2016, 07:08 AM
sruelle is offline
Find More Posts by sruelle
Team Horizon
sruelle's Avatar
United States, MI, Ann Arbor
Joined Feb 2005
Well Glenn, been there too...
Just in case you want to go a little further as you have removed the windows...
I did something similar last fall and decided to condemn the Windows in order to bring back strength in the area. My intend is to avoid shear and compression, plus it stiffen the landing gear support.
Glass first
Sans titre by steffruelle, sur Flickr
Then carbon fiber behind front former, on the TE area and on the top seam (it split there)
Filler and sanding
Then paint, matching code for R&M paint is MA145.10 ( thank Scott for the fix !)
And vinyl to simulate the Windows
Pretty happy of the result
Here is the flickr album with all pictures
https://www.flickr.com/photos/422200...7654659741610/
Stephane
Team Horizon
sruelle is offline Find More Posts by sruelle
Old Apr 12, 2016, 05:32 AM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
just a quick one for those that have fitted the air brakes. Do the self tapping screws come with the air brakes or are they supplied in the blanik kit? My Air brakes have no screws with them but i found 6 screws in the kit that fit the bill and just wondered? as i didn't want to steal from the kit! Thanks
cheers Chuck
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Apr 12, 2016, 06:27 AM
barracudahockey is offline
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
It's been a while but I'm pretty sure they are in the kit
barracudahockey is offline Find More Posts by barracudahockey
Old Apr 12, 2016, 06:29 AM
Lbuff1 is offline
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
They're in the Kit.
Lbuff1 is offline Find More Posts by Lbuff1
Old Apr 12, 2016, 07:15 AM
Joined Dec 2007
Thanks guys all fitted!
Chuck
Old Apr 12, 2016, 11:19 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Those are probably the easiest spoiler to install! Only issue I had was the floor inside the spoiler bay was too high, the spoilers does not sit flushed with the wing surface. I have to take some of the wood out.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Apr 13, 2016, 07:25 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
I also had to remove a little to get them flush
Old Apr 15, 2016, 10:41 PM
Joined Dec 2007
Brian, an EAJ
Must of fixed that problem for the second batch as mine fit good!
Ok Question time again
Whats the general consensus on the Wing Tips?
Do you just glue them on and have the lump at the end of the wing for storage.
Or
Do you make them removable?
Looking at it making them removable looks easy. The 2 holes already in the tip could have some carbon rod fitted and slotted into the end of the wing then a little tape to hold it in place
So what did most do? What would you do? would you do what you did do again if you had the option?
thanks guys
Chuck
Old Apr 16, 2016, 05:53 AM
Joined Sep 2004
I'd probably make them removable if I did it again with some carbon rod and rare earth magnets, though the wing bags I had accounted for them.
Old Apr 16, 2016, 06:50 AM
Lbuff1 is offline
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Chuck,
When I build one for a friend, I did exactly what Andy said, put two carbon rods in with a tube in the wing, recessed a magnet in the parts and it was done. Piece of cake and never a problem.
Len
New Product The first official Piper L-4 Grasshopper 250 ARF by E-flite Thread! P-51C Scale ARF/RTF 1340 Apr 11, 2016 09:50 AM
Help! Top Flite Flite Streak C/L ARF .25-.40,41.5" saab2 Control Line 14 Apr 24, 2015 10:24 AM
For Sale E-Flite Piper L-4 Grasshopper 250 ARF CryHavoc Aircraft - Electric - Airplanes (FS/W) 1 Apr 02, 2011 10:52 PM
Found E-Flite Piper L-4 Grasshopper 250 ARF hbsurfer Aircraft - Electric - Airplanes (FS/W) 2 Nov 30, 2010 10:38 PM
Discussion E-Flite Piper L-4 Grasshopper 250 ARF ducatirdr Scale ARF/RTF 2 Sep 24, 2009 08:22 AM
