Old Oct 20, 2003, 08:07 AM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
Corona Final assembly questions: How does it look to you ?
Hi,
I am completely new in the helicopter arena and I need your help.
Here some different parts and how they look. Any comment, did I forget something, something that needs attention ? anything you could spot.
Thanks !
The Gyro is now attached, on a piece of wood. The gyro has no contact with the wood, from any side, and is put on the absorbing shock tape provided with it.
Behind is the FMA-Copilot.
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Oct 20, 2003, 08:16 AM
Joined Sep 2001
other side
Old Oct 20, 2003, 08:17 AM
Joined Sep 2001
closer
Joined Sep 2001
Motor gear
Old Oct 20, 2003, 08:19 AM
Joined Sep 2001
Is the space between the teeth good ?
Old Oct 20, 2003, 08:21 AM
Joined Sep 2001
For the FMA Co-pilot, I will do what I saw from people who used it and build a plate, on the back, above the tail boom.
Old Oct 20, 2003, 08:22 AM
Joined Sep 2001
For the Antenna, is it ok to make it turn around the tail boom, until it is fully extended ?
Old Oct 20, 2003, 09:06 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Do not wrap the antenna around the tail boom.
It should not touch any metal at any point, because this may cause interference.
I haven't used the FMA copilot, but I've heard it needs to see the horizon in all directions. If so, then your mounting may not work, because the crutch is blocking the view of the horizon.
Toshi
TMorita is offline Find More Posts by TMorita
Old Oct 20, 2003, 09:35 AM
Joined Sep 2001
Thanks Toshi,
I setup the GY401, following your instructions, in your manual.
For the Copilot, FMA manual explains that you should put it in diagonal, indeed, to make sure the cockpit does not interfear.
As for the antenna. What do you think to tie it to the landing gear then, which is not made of any metallic part ?
Old Oct 20, 2003, 10:30 AM
t_predator90 is offline
Find More Posts by t_predator90
-=Futaba RuLEz=-
t_predator90's Avatar
Netanya, Israel
Joined Sep 2002
Hi patrick.
What I've seen a lot of people to, is run some fuel tubbing along the boom, and inside it the antenna (I've got about 44 cm spare, if you want).
Looks great so far! Where (and when) will you be doing the test flight?
t_predator90 is offline Find More Posts by t_predator90
Old Oct 20, 2003, 10:44 AM
Bourbon is offline
Find More Posts by Bourbon
Kent, Washington
Joined Nov 2002
I think you'll find out that the rear landing gear mount will need to be moved farther forward so you can move the battery farther forward to balance your heli. There's no way it will balance the way you have it and still be able to have the battery in the rear mount, unless you add weight to the front of the heli.
Bourbon is offline Find More Posts by Bourbon
Old Oct 20, 2003, 12:43 PM
TMorita is offline
Joined May 2002
Oh, I thought you mounted the Copilot was in front of the gyro.
If you build a platform, it should be okay.
I ran my antenna through one of the holes in the tail fin, then taped it to itself. Seems to work ok.
Toshi
Toshi
Old Oct 20, 2003, 04:10 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Move the ESC away from the RX. They should not be next to each other at all.
Keep the antenna away form the ESC when you move it too.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Oct 20, 2003, 06:19 PM
Joined Sep 2001
Thanks Fred, will do.
Question Installed my ParkBEC, how does it look? Q: How do you know if it's working? eckcessive Power Systems 5 Feb 10, 2007 12:36 AM
About finished shaping, how does it look? gunnisonflyer Slope 8 Sep 16, 2004 01:30 PM
Corona final assembly CAWayne Electric Heli Talk 2 Feb 27, 2003 11:40 AM
Corona - Final Assembly Questions milkman Electric Heli Talk 5 Oct 28, 2002 09:47 AM
