Old Nov 08, 2011, 12:04 AM
skubacb is offline
Find More Posts by skubacb
skubacb's Avatar
Tucson, AZ
Joined Aug 2006
PowerLab 8 Presets for LiIon and LiManganese
I can find no presets for either LiIon or for LiMn batteries.
I would think that these should have been provided with the charger since the specs specifically state the charger works with them.
Have I just missed this? I did a search of the manual and these batteries only show up in the specifications.
Where do we go to get or share presets. Does FMA have a site specifically for us to download more presets?
skubacb is offline Find More Posts by skubacb
Old Nov 08, 2011, 06:51 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
LiIon charge the same as LiPoly.
Very old LiIon were marked as 3.6V and thus can use the LiPoly Long Life 4.1 Preset.
Newer LiIon are marked 3.7 (same as LiPolys) and thus can use the LiPoly Presets.
LiMn .
There was a request for a higher voltage (charge to) months ago and the upper available limit in LiPoly was increasted to 4.3 V.
Remember that you can remame and modify the Presets to match your needs.
Sharing Presets.
There was talk of FMA creating a data base to share custom fuel tables but this has not happened as yet. It is very simple to create then save any Preset and thus share it with other PL8 owners.
Care to post requirements for charging LiMn as a refresher?
I seem to remember that LiManganese charge tge same as LiPolys or atleast the ones from years back did.
Charles
Old Nov 17, 2011, 03:57 AM
skubacb is offline
skubacb's Avatar
Tucson, AZ
Joined Aug 2006
Not an expert in batteries. That is why I expected FMA to setup a database of verified presets we could download.
All of my other chargers use a different cell voltage for LiIons.
Also, FMA advertises that this charger is for LiMn and LiIons. So I would expect them to have presets already available for us. Why make each user have to develop/setup a preset for something the charger is advertised to do?
I will do some research but feel that FMA should be the one doing this for us.
Discussion Powerlab 8 Parallel Charging KAW_Concours FMA Direct 36 Sep 30, 2012 10:47 AM
Discussion Powerlab 8 regenerative discharge question? Eddie500 FMA Direct 11 Nov 09, 2011 03:05 PM
Discussion PowerLab 8 IR Measurements squid FMA Direct 1 Sep 13, 2011 03:27 PM
Question Powerlab 8 for $200?! lipper2000 FMA Direct 7 May 18, 2011 10:54 PM
Discussion PowerLab 8 V2 - Safety Code 52 martinwinlow FMA Direct 3 Apr 24, 2011 03:39 AM
