Old Aug 08, 2011, 10:35 PM
boss99er is offline
Find More Posts by boss99er
Omaha NE
Joined Aug 2009
UM T-28 trimming help
Hey guys, I just got a used T-28 and could use a little help getting it trimmed out right. My maiden tonight was great, except I couldn't get it to fly straight and level. I always had to hold right aileron, and quite a lot of down elevator. It seemed to be tail heavy, so I slid the battery as far forward as I could, but it didnt help. I also cant figure out the constant tendency to roll to the left. I've been out of the plane game for a while....so I could use some pointers. Is there something I'm forgetting? All control surfaces seem straight and undamaged. Oh, while flying I had the landing gear off the plane. Thanks guys!!!
boss99er is offline Find More Posts by boss99er
Old Aug 08, 2011, 11:16 PM
Great_Goose is online now
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
I had the same problme this morning with my UmT-28 see my post.
Great_Goose is online now Find More Posts by Great_Goose
Old Aug 08, 2011, 11:27 PM
binaryclock is offline
Find More Posts by binaryclock
I hate winter!
binaryclock's Avatar
Canada, ON, Barrie
Joined Jul 2011
Could be wind. The UM T-28 is very sensitive to wind changes/gusts. It will make you bank or roll with a slight wind. Best is just to fly with no wind to learn. After about 10 flights you can fight with wind with no problems.
binaryclock is offline Find More Posts by binaryclock
Old Aug 09, 2011, 07:42 AM
DaveG is offline
Find More Posts by DaveG
DaveG's Avatar
Houston, TX, US
Joined Jun 2000
I waited until it was dead calm to trim out my T-28. It flys well with the battery fairly well forward (I usually fly with Hyperion 160s) and quite a bit of down trim for the elevator and some right aileron trim. It's tough to battle any wind and figure out the T-28 flight characteristics when you first start flying it. Once she's dialed in, she's a jewel, so be patient and persistent.
DaveG is offline Find More Posts by DaveG
Old Aug 09, 2011, 07:44 AM
boss99er is offline
Omaha NE
Joined Aug 2009
Hmmm....yeah, I suppose that could have been it, but it did it no matter which way I was flying. If it was wind, it would have switched which way the wind was pushing it based on direction of flight. But also, I'm not new to planes at all, just been out of it for a while.
Old Aug 09, 2011, 07:45 AM
boss99er is offline
Omaha NE
Joined Aug 2009
Oh yeah, I certainly dont plan to give up! ;-)
Old Aug 09, 2011, 07:52 AM
DaveG is offline
DaveG's Avatar
Houston, TX, US
Joined Jun 2000
I've flown R/C for over 30 years and every plane, especially the micros, is a new experience for me.
Old Aug 09, 2011, 08:35 AM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
No that's not exactly correct. You'd think this would be how the wind affects the plane but sometimes the wind will always push it to a certain direction for whatever reason.
Question - when it's banking is it also losing a bit of altitude or gaining altitude, or does it just roll flat out? Watch the nose to see if the nose drops during the bank. If this is the case then wait for a really calm day then try. If it still banks to the left or right then check the rudder to see if it is still attached properly. The rudder shouldn't be majority stiff, but stiff enough that it won't wiggle too much at the bottom during flights. Add some tape to the rudder joint to the vert stabilizer if it seems too loose.
The rudder will make a plane's nose drop slightly a few degrees so if there is any movement in the rudder you'll bank and pitch downwards.
Old Aug 09, 2011, 08:52 AM
boss99er is offline
Omaha NE
Joined Aug 2009
Well, I originally did suspect it was a rudder problem. And I'm still not convinced its not. The thing that made it hard to diagnose whether it was a rudder problem was the fact that it seemed to be tail heavy. Maybe these little micros just take a little getting used to. This is the first time I've flown a UM, so I'll just keep at it.
Old Aug 09, 2011, 09:02 AM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
Why do you say it's tail heavy? Because it constantly wants to climb? The UMs always seem to want to climb with heavy throttle because of the lift generated on the wings, but in general it shouldn't be tail heavy at all if it's stock.
Try flying without the gear on and see if that helps. Flying without the gear makes it fly much better in my experience. However I keep my gear on for nice landings.
Old Aug 09, 2011, 09:28 AM
mu2freighter is online now
Find More Posts by mu2freighter
easily confused
mu2freighter's Avatar
Nashville Metro, Tennessee, United States
Joined Sep 2003
That's because these planes are way overpowered from a scale perspective. If you're flying around at full power, the high airspeed makes for a relatively tremendous amount of down force from the horizontal stabilizer, and the propwash from abruptly increasing to full power does much the same, with the nose pitching up as a result.
I take off with full power, knowing that as the airspeed increases so will the upward pitching tendency, so I know to increase forward pressure on the elevator right after takeoff and I'm ready for it.
Once the plane is up and away, I reduce power to about 75% which nicely reduces the nose's tendency to rise as well as yielding a more scale climb.
If you're in the adrenaline junkie camp and like seeing your planes zip around at a scale Mach 2, mix in some down elevator with full throttle. It's a preference thing, some like it, but when I see a scale warbird flitting around like a hamster on speed I find it repulsive. The T-28 does a nice scale speed at around 50% throttle, which works for me.
Entering or leaving a turn in these UMs requires a fair bit of elevator to keep the nose from dropping or rising abruptly respectively, more than you'd see from a larger model, but that's just a matter of practicing until you're comfortable with the quirk.
mu2freighter is online now Find More Posts by mu2freighter
Old Aug 09, 2011, 09:31 AM
boss99er is offline
Omaha NE
Joined Aug 2009
Well yeah, most planes will pitch up at full, but this plane seemed to just drag its tail around. I had the gear off on my maiden because I was landing in a grass park. Maybe tonight I'll throw the gear on, charge up a couple batteries, and try again. Who knows....maybe I just had the maiden jitters. :-)
Old Aug 09, 2011, 09:33 AM
boss99er is offline
Omaha NE
Joined Aug 2009
One of the odd things it did a few times was I'd just be flying level, all a sudden without me touching the throttle it would just nose up and stall.....that was the strangest thing...like I've said...I'm not new to flying planes, but I am VERY new to flying UMs.
Old Aug 09, 2011, 09:45 AM
easily confused
Joined Sep 2003
That could likely be choppy air causing a localized (and usually random) gust that upsets the plane. A sudden straight on gust will make the nose pitch right up.
These planes are incredibly light and a little teeny puff can cause an upset. I'm still getting used to that, and the T-28 isn't helping since it flies like a larger plane...right up till a gust knocks it sideways, pitched way up or pitched way down.
I went out to fly this morning and knew it wasn't going to happen as soon as I got outside; I could feel the wind and the tree tops were waving...in different directions!
Fly a UM in gusty unstable air and you're just asking for trouble.
PS- trim the plane in dead calm air at about half throttle, that should keep it nice and level, then get used to its quirks from there. As I mentioned, rolling in and out of turns requires a lot of elevator input at various airspeed and power settings, and if you want to fly around at full power all the time you either have to expect to hold forward stick pressure full time or mix in down elevator with full throttle. I would NOT trim the plane to fly level at full power, once you reduce throttle the nose will drop like a stone as a result.
Old Aug 09, 2011, 09:47 AM
I hate winter!
Canada, ON, Barrie
Joined Jul 2011
Honestly, sounds like wind gusts. UMs are extremely sensitive to wind gusts. Sometimes you are shielded by the smallest gusts by fences, trees and houses, but 10-20 feet up your UM feels those gusts. A small gust of about 5km can make it do what you just described if you aren't above 50% throttle or so. Even then at higher throttles, the UM will have increased lift if flying in to the wind and gain like 2 feet in a matter of a second or less
I have days all the time where I see the flag is not moving, but about 10 feet up my plane gets thrown all around from gusts.. very weird when that happens but it does with UMs. It's probably just wind tunneling through a treeline or something or even thermals.
Wanted Wanted: UMX Beast for a UM T-28 and a UM sukoi 26m 14jmilne Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 13, 2011 06:59 PM
Help! UM t-28 help !!! omer921 Micro Ready-to-Fly 9 Feb 17, 2011 12:58 PM
Question UM T-28 reciever help no1photo Electric Plane Talk 1 Feb 02, 2011 05:01 PM
Discussion Next step - UM T-28 or T-28 turnerm Beginner Training Area (Aircraft-Electric) 23 Jan 15, 2011 03:04 PM
Found Trade: BNIB PnP UM 4 Site for PnP UM SuXP or PnP UM T-28 elvill Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Nov 09, 2010 09:12 AM
