Old May 31, 2011, 07:07 AM
Monhty is offline
Find More Posts by Monhty
Espaņa, PM, Palma
Joined Jan 2009
USB Rx Manager connection to Vario
Hi,
the RX Manager help shows the connection between them using a V-cable to the S port
can the RX-S port also be used?
The supplied V-cable has only male-connectors and a female is needed for the S-port
thanks for your help!
Monhty
Monhty is offline Find More Posts by Monhty
Old May 31, 2011, 06:43 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Monhty View Post
Hi, the RX Manager help shows the connection between them using a V-cable to the S port can the RX-S port also be used?
The supplied V-cable has only male-connectors and a female is needed for the S-port thanks for your help! Monhty
"Vario", there are several different variometer, if meaning one of the Hitec telemetry items, then please refer to the telemetry section under the FAQ page below, otherwise:
Aurora 9 - After Market Accessories
"RX-S port" = SPC Port?. "Supplementary Power Connection" is for power input to the receiver side of the transceiver only, no data in nor power out.
Optima Transceiver (RX) - SPC - SPC connection & Lead Detailed
Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Jun 01, 2011, 12:21 AM
Monhty is offline
Espaņa, PM, Palma
Joined Jan 2009
Thanks for all that info but its a Royal Evo and its the Altimeter-Variometer sensor
Monhty
Question GoPro USB Connector loose connection / bad solder job or feature? AnnihilaT FPV Talk 4 Sep 24, 2011 01:52 AM
Discussion Satellite Rx connection for RD921 mike012321 Electric Sailplanes 2 May 01, 2011 10:36 AM
Help! Help on Assan Rx Tx Usb connection Rxgto Radios 0 Mar 08, 2009 09:38 AM
Microlader USB connection SBK Formosa Batteries and Chargers 1 Mar 03, 2005 07:00 PM
Dual RX Pack Manager AustinTatious Batteries and Chargers 5 Sep 28, 2004 12:22 AM
