Old Feb 03, 2013, 10:51 AM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Originally Posted by IfIHadWings View Post
Tom...are you thinning these and airbrushing, brush painting or something else? FlyRC article mentions 5:1 thinning for airbrush...just wondering knowing these paints can be very thick.
Also, are you using the guac on the underside?
Touch-ups I just brush full strength. Spray, I thin about 4/1 with windex (not water!) dries faster and sticks better.
Yes, I am using the guac on the underside. picture showing how well it matches below. It still needs one more coat to get rid of the brush strokes. Painted is the brown elevator joiner.
Tom Hunt is offline Find More Posts by Tom Hunt
Old Feb 03, 2013, 11:00 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Hurricane Setup Summary
With the price reduction on the Hurricane, I thought I would collect my setup for folks just starting out. I have attached a document of all the settings, dual rates, and tips that helped me. Many of them come from this thread.
tclaridge is offline Find More Posts by tclaridge
Old Feb 03, 2013, 11:04 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
I walked into my local HobbyTown with 300 bucks in my pocket after having sold a nitro truggy, my last RC car. I walked out of the store with the E-Flight Hawker Hurricane for the princely sum of..........................$109.00. I couldn't believe it. They had two and when the guy in back of me in the cashier line heard that he bought the other one on the spot. I have her built and ready to maiden. It is just an AWESOME looking plane.
chucksolo69 is offline Find More Posts by chucksolo69
Old Feb 03, 2013, 11:52 AM
GhostStone is offline
Find More Posts by GhostStone
Soli Deo Gloria
GhostStone's Avatar
United States, IN, Fort Wayne
Joined Jan 2012
Well done Chuck! Look forward to hearing about your maiden.
GhostStone is offline Find More Posts by GhostStone
Old Feb 03, 2013, 11:53 AM
Soli Deo Gloria
GhostStone's Avatar
Joined Jan 2012
Thanks for the info. The more I can read the better.
Old Feb 03, 2013, 12:58 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
@ChuckTseeker - Thanks for making that video on installing the 15-25 retracts on the Hurricane. I had your video next to me for easy referencing as I was installing mine.
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Feb 03, 2013, 01:05 PM
Soli Deo Gloria
GhostStone's Avatar
Joined Jan 2012
I've been watching his videos as well. Picked up my retracts yesterday from LHS. So when my Hurricane arrives this week I will use his video for installation info after I put a couple of flights on her with fixed gear.
Old Feb 03, 2013, 01:13 PM
IfIHadWings is online now
Find More Posts by IfIHadWings
Eat, Fly, Dream, Repeat...
IfIHadWings's Avatar
United States, GA, Jefferson
Joined Jun 2012
Radiator venturi
I've been kicking around the cooling/venting issue and a solution that would retain the stock look.
I'm not an engineer, so I have no idea if the dimensions are correct to create the necessary draw but it might be worth a try.
IfIHadWings is online now Find More Posts by IfIHadWings
Old Feb 03, 2013, 02:54 PM
Joined Jan 2012
Those of you flying the Hurricane with E-Flite retracts and Spektrum, are you adding an external BEC?
Mine is ready to go, but I don't have any more Castle BECs at home. Trying to decide whether to fly it or wait until I get a BEC. I'm paranoid the E-Flite 60amp ESC might not be able to handle flaps and retracts.
Old Feb 03, 2013, 02:55 PM
Babadush is offline
Find More Posts by Babadush
Babadush's Avatar
United States, VA, Richmond
Joined Aug 2012
Originally Posted by Plane Chaos View Post
+1 on this sound advice
I use the glue that comes with the planes for loctite. It works really well.
Babadush is offline Find More Posts by Babadush
Old Feb 03, 2013, 03:00 PM
Plane Chaos is offline
Find More Posts by Plane Chaos
Joined Dec 2009
Some folk have fitted BEC's, others not
... the stock Hurri set up can handle addition of the flaps with the E-flite retracts.
Some folk insist on fitting BEC's by default; certainly does no harm.
Plane Chaos is offline Find More Posts by Plane Chaos
Old Feb 03, 2013, 04:53 PM
Loukhan is offline
Find More Posts by Loukhan
Loukhan's Avatar
Joined Apr 2012
Originally Posted by Coot83 View Post
That stuka looks like a veteran...is that the stock spinner or an aftermarket one?
Coot
The prop and spinner are stock. It's the FMS model.
RE: hot ESC- in talking to some of the guys I fly w/ I'm now thinking ill just add a UBEC, they think that and adding more ventilation should keep it cool. I'm looking at
1)closing off (partially first, then test) the back half of the radiator. *I will be adding a screen to the front of the rad to keep out dirt, as I fly off dirt fields.
2) adding a gap on either side of ESC (maybe doing the straw idea to it).
3) opening up exhaust stacks and venting to reduce internal fuse pressure.
Loukhan is offline Find More Posts by Loukhan
Old Feb 03, 2013, 05:01 PM
Coot83 is online now
Find More Posts by Coot83
You haz hurricane?
Coot83's Avatar
United States, VA, Alexandria
Joined Jun 2012
What part of the plane is FMS model?
Coot
Coot83 is online now Find More Posts by Coot83
Old Feb 03, 2013, 05:28 PM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
dozens of flight on mine not a problem with stock esc.
Old Feb 03, 2013, 06:38 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Coot
FMS is a popular manufacturer
Diesel6401 is offline Find More Posts by Diesel6401
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4104 Oct 11, 2015 02:51 PM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 4 Aug 13, 2013 05:47 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 11:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 11:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 12:17 PM
