Old Jun 20, 2003, 12:08 PM
xalex is offline
Find More Posts by xalex
Joined Feb 2003
TigerMOth + Litium Ion = What motor ?
I have a tiger moth that i bought used. Now i have 7.2v Lithium Ion Hanycam battery (duracell dr5) that i want to use with it. What motor should i get for it ??
IPS sytem or the EPS-100 ??? And what gear ratio should i get ??
Ill apreciate any help possible
xalex is offline Find More Posts by xalex
Old Jun 20, 2003, 12:31 PM
pc_pilot is offline
Find More Posts by pc_pilot
USA, NY, Yonkers
Joined Aug 2002
The tiger moth didn't come with a motor? If not, then get the stock motor and gearbox for the moth. It is the IPS-A drive with the 5.86:1 gear ratio and use the 9x7 prop. I use this setup with my 2 cell 830mah qualcom battery and I get more than 30 minute in the air and I still have power spare.
pc_pilot is offline Find More Posts by pc_pilot
Old Jun 20, 2003, 01:48 PM
xalex is offline
Joined Feb 2003
Cool , thanks pc pilot
Old Jun 20, 2003, 02:37 PM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
I am using the stock motor/gearbox on the 1020 Kokam LiPoly cells. Long flight times, no difference in heat buildup in the motor or cells... If you can make it work, use it. Make sure you use a lithium battery charger. Standard chargers (for NiCd/NiHM) do not work for lithium cells.
Trikster is offline Find More Posts by Trikster
Old Jun 20, 2003, 10:44 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
For me the single motor and 2 CELL Etec 1200s was decent but no real kick to get up quick or power through the occasional gust that try to bat you down or drive you into a tree. I switched all my planes,Moth,Cub,IFO to dual IPS and have never looked back. Single best bang for the buck for these planes.
JIMJAM is offline Find More Posts by JIMJAM
Old Jun 21, 2003, 10:54 AM
xalex is offline
Joined Feb 2003
thanks guys ! , yea i have sima charger that charges lithium batterys . I was wondering if i could use the edp100 A as a motor with my lithiums ??
Tigermoth + lithium ion = what motor ? xalex Scratchbuilt Indoor and Micro Models 6 Jun 23, 2003 02:41 PM
What motor/gearbox combo do you suggest? Rob Andrew Electric Plane Talk 4 Sep 06, 2001 04:51 AM
What motor, gear, battery config for ElectriCub pipercubman Electric Plane Talk 3 Aug 03, 2001 12:08 AM
What motor is this? David Hogue Electric Plane Talk 3 Jul 22, 2001 01:39 AM
Help!!! Airplane, battery, what motor??? FlyerGirl Electric Plane Talk 4 May 26, 2001 12:36 AM
