Old Feb 28, 2013, 12:54 PM
mat3415 is offline
Find More Posts by mat3415
United States, FL, Miami
Joined Sep 2011
Originally Posted by zeezee View Post
If you talk to Jesse or Jeff they will solder whatever connections on for you. These guys are the best!!! Where else can you buy a lipo that has gone bad or puffed and got a free replacement........IN 3 Days????? Dave/zeezee
So I emailed them yesterday about sodering on xt60s for the battery and they said they would not, as the liability is too great... Looks like I'm just gonna get the male xt60 to female t connecter
mat3415 is offline Find More Posts by mat3415
Old Feb 28, 2013, 01:01 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Originally Posted by flyhigh300 View Post
Well .. no I dont think so..
the only time it was noticeable was ...as I exit a turn.. very noticeable.
I was not applying more power .. most cases I left it the same..
on some turn I banked hard and picked up speed.. as it got in a bit of nose dive.. seem like all by itself.. and it would balloon up..
so I would apply down elevator to stop it.. then continue forward..
all seem ok.. I could power up and it seem normal .. no odd behavior..
I did two 20min flight today.. just trimming it out..
first few minute was super nose heavy then I got it to tail heavy,
Then finally very nice expect for that one Issue..
its seem the sweat spot is very small .. not sure ..
I hope I can do some more testing .. in the next few days..
I have My CG set touching the aft part of the spar. mine flys like its on rails...and will fly inverted with almost zero down elevator.....it is neither nose heavy..OR tail heavy....give it a try ( it wont crash) and if you dont like it..go back to where yours is now.
Also, if you are flying straight ahead at slow speed...then push the throttle to max....does it ballon up?? if it does..you need to adjust the two top thrust screws IN ( the same nuber of turns each) and the bottom 1's out a tad ( the same number of turns each)
That will adjust more down thrust into your model...and when you get it just right...you can go from gliding to FULL throttle and the nose will stay put....remember I can do this with a .10 motor on mine..again ..straight as if on rails..
Originally Posted by F-86FLIER4LIFE View Post
It seemed the tendency was that overly large motors would rip up the motor mount,
I do not think Anyone has had a "Motor Mount" Issue...unless they crashed bad...if installed correctly...the motor mount is Very strong...and people have all sorts of motors in them...some even mounted infront of the mount...the FC has no Motor mount issue.
Pat
Weed89 is offline Find More Posts by Weed89
Old Feb 28, 2013, 04:38 PM
Doushiyou12 is online now
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
Hello FC owners,
new FC owner here. My lady bought me this kit and I am so pumped to get this started. I just received the turnigy 3536/8 motor with x mount so I will be making making a motor mount for the x mount. I have a BP 2217-9 motor laying around good enough for 35oz planes and i am wondering if it would be enough for the FC. reason I ask is because its lighter and I want to fly the FC as slow as possible.
Also does anyone know if I can just reverse the shafts on either motors to maybe possibly use the stock motor mount?
The FC will most likely go under the paint booth this weekend along with my other builds. I have plans to modify the landing gear. I will be using foam tac glue to put her together as well.
Thanks for your time.
Doushiyou12 is online now Find More Posts by Doushiyou12
Old Feb 28, 2013, 06:17 PM
eMoon is offline
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
Not sure foam tac will work. Most folks, and the manual, say to use straight up medium CA with kicker. As this Elapor foam ain't no ordinary foam, lol.
eMoon is offline Find More Posts by eMoon
Old Mar 01, 2013, 04:24 AM
wileyrc is offline
Find More Posts by wileyrc
wileyrc's Avatar
Joined May 2007
Im in I will be purchasing a funcub from my local hobby store on wednesday. Thanks for all your advice.
wileyrc is offline Find More Posts by wileyrc
Old Mar 01, 2013, 06:35 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by newTOpro View Post
Not sure foam tax will work. Most folks, and the manual, say to use straight up medium CA with kicker. As this elapor foam ain't no ordinary foam, lol.
Canopy Glue works too - CA tends to be a bit stiff/brittle for me
mutha is offline Find More Posts by mutha
Old Mar 01, 2013, 09:23 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
Originally Posted by Doushiyou12 View Post
Hello FC owners,
You should be able on the Turngey one.
I have broken my shafts a few times on crashing. And I use shafts that don't have the "snap ring".
But no problem. the prop "pulls" the motor together.
Flybynight2 is offline Find More Posts by Flybynight2
Old Mar 01, 2013, 09:48 PM
Tcat is offline
Find More Posts by Tcat
Joined Jul 2004
Who makes the L-4 and bush plane trim sets I saw in this thread?
Tcat is offline Find More Posts by Tcat
Old Mar 02, 2013, 08:09 AM
flyhigh300 is online now
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
Hello all..
Thanks for all your advised..
Just a slight set back..
I had been flying with 10x7 props as it was all I had..
picked up a 11x7 and 12x6 from the LHS ..(1hr away)
Well I guess i did not install the motor mount right.. or 12x6 was to much as I ripped the motor right out of the nose,
Plastic parts snapped right behind where the screw ends ( about 1/2) part of the plastic..
10x7 was ok but fly's like a trainer.. wanted a bit more punch,
So I guess I got it..
Power Setup is
60amp esc - was all I had -
28x14 Sunny Sky - 900KV -
on 4S
So Some repairs are in order .. :-(
Pat
flyhigh300 is online now Find More Posts by flyhigh300
Old Mar 02, 2013, 10:56 AM
bicyclemonkey is offline
Find More Posts by bicyclemonkey
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
Sounds more like that prop wasn't balanced.
bicyclemonkey is offline Find More Posts by bicyclemonkey
Old Mar 02, 2013, 12:02 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
http://www.modelmarkings.com/index.p...liplex-fun-cub They are on vacation till march tho. joe
cracksmeup is offline Find More Posts by cracksmeup
Old Mar 02, 2013, 12:44 PM
grand14 is offline
Find More Posts by grand14
Joined Oct 2012
What dr and expo setings shod i use on my funcub?? cant find it any where in the manual?
grand14 is offline Find More Posts by grand14
Old Mar 02, 2013, 03:01 PM
Randbo39 is offline
Find More Posts by Randbo39
Randbo39's Avatar
United States, AR
Joined Mar 2009
My builds. The Yellow one is mine and the L-4 is one I did for a friend.
Randbo39 is offline Find More Posts by Randbo39
Old Mar 02, 2013, 03:34 PM
Will it ever Fly?
Joined Nov 2011
Nice.
But I have to paint mine with lots of Red, so I can find it after a crash
Old Mar 02, 2013, 03:35 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
on that L4, how did you make that landing gear? I have seen fun cubs that have their wheels all spread out from the landing gear bending outwards, and was looking to do something like that.
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
