Old Jul 23, 2002, 08:21 AM
KDR
Joined Jul 2002
Switchback help
Ok, got my switchback together, and everything checks out properly (i.e. CG, and weight) I am using a gws 370 motor and 8 cell 600 pack. I tried flying it, but have no idea what is wrong, it takes off the ground fine until about 3 or 4 feet, and then won't climb any higher. Just can't get up in the air, its like its struggling. Can anybody come up with any ideas? Thanks for the help
KDR is offline Find More Posts by KDR
Old Jul 23, 2002, 09:04 AM
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
A really easy mistake to make is to put the prop on backwards. The letters face forward. The SB should climb nearly vertical so something big is wrong. Start with the prop and we'll go from there. I'm sure we can figure this out quickly.
Doug
CoClimber is offline Find More Posts by CoClimber
Old Jul 23, 2002, 09:38 AM
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
The prop would be my first guess too.
If the prop is on right check the throttle trim, throttle channel ATV (if your tx has it), and your esc (if it has a arming squence or programming).
Just in case.
BC
Basketcase is offline Find More Posts by Basketcase
Old Jul 23, 2002, 09:59 AM
KDR
Joined Jul 2002
ok...
im sure its not the plane, prop is on right, but I think as the prop is spinning its pulling the shaft out a little so its not meshing correctly with the other gear, to much play. I am pulling the motor out and going to maybe add a washer under the circlip so its got less play. Thanks for the ideas, and if you got any more, keep them coming. Thanks
Old Jul 23, 2002, 10:24 AM
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
KDR, the gear is pressed on and can be pushed back if needed. The thing is, that motor produces a lot of power and unless it is seriously binding, it would fly the SB fine. What kind of ESC are you using?
Doug
Old Jul 23, 2002, 11:39 AM
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
I routinely do touch and goes using only half throttle, so you'll definately know when you've found the problem. She'll be a rocket compared to what you're seeing now!
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jul 23, 2002, 03:23 PM
KDR
Joined Jul 2002
prop size
what is the correct prop for the 370 motor. Thanks
Old Jul 23, 2002, 03:26 PM
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
The prop size is 9x7", aka GWS 9070.
Switchback Help Needed! akh223 Parkflyers 8 Jan 05, 2003 07:38 PM
Switchback Help mtfbwymb20 Parkflyers 1 Sep 02, 2002 03:09 PM
Switchback Help cadconversions Parkflyers 43 Jul 13, 2002 09:05 PM
