Old Dec 19, 2013, 08:56 PM
JGuilty13's Avatar
United States, MI, Royal Oak
Joined Nov 2005
New Product
Change Sun 64mm 12blade unit w/3200kv - 3s
Sorry if this has been posted before, but Ive never seen it. 12 blade 64mm unit w/motor from CS.....I found this on Ebay:
http://www.ebay.com/itm/Change-Sun-6...item3a8907e282
Says its only for 3s though. Any thoughts on this one?
Website description:
Rotor Diameter: 64mm
Outer Diameter:67mm
Weight: 98 g
Propeller: 12 Blade Propeller
Working Voltage: 3s
Motor : Brushless Motor2627 3200kv
Maximum Current: 25A
Thrust: 580kg
JGuilty13 is online now Find More Posts by JGuilty13
Old Dec 19, 2013, 09:26 PM
Joined Oct 2013
I'd go for this one.....
http://www.ebay.com/itm/Change-Sun-6...item3cda205c73
fastblade is offline Find More Posts by fastblade
Old Dec 19, 2013, 09:38 PM
JGuilty13's Avatar
Joined Nov 2005
well played, didnt notice the 4s version!
Old Dec 20, 2013, 03:54 AM
Greece, Attica, Athens
Joined May 2011
Nice find. Looks like a new CS release.
I would expect that the 3200kv version would be a powerful 4S setup if the motor holds up.
Looks like the 2500kv and 3200kv motor choices were done to make these fans direct replacements in 64mm PNP airframes.
Thrust and amps are about the same as the equivalent 5/6 blade setups.
anlucas is online now Find More Posts by anlucas
Old Dec 20, 2013, 08:40 AM
Joined Oct 2013
yea I'd get just the blades and swap it for more kv. 3200-3600 would give some nice thrust.. Probally around 1.2kg and up depending on kv and watts. Just gotta watch the amps for the esc......... I'm looking to upgrade my 64mm also...The DPS 10 blade has a 2950-3300 motor in it and is getting 1.4kg.... $63.55.. and it is a aluminum housing. So if I can't get something cheaper overall than DPS.. Then I'll just by that... I need 2 for my jet so looking for alternative....
Old Dec 20, 2013, 01:30 PM
Joined Oct 2013
I'm looking @ this now....
http://www.nitroplanes.com/53p-20018.html
Old Dec 20, 2013, 04:48 PM
Joined Nov 2011
Originally Posted by fastblade View Post
the specs :
Blade Diameter: 63.3mm
Outer Case Diameter: 67mm
Wall Thickness: 1.1mm
EDF Length: 44mm
Front Shroud Diameter: 79mm
Blade Type: 12
Shaft Size: 8mm
how the hell can we get 8mm motor shaft for this fan?????
typo? hopefully :-)
the photo shows the fan comes with two adapters, I guess it would
be 3,2mm and 4mm adapter as normal.
but I hope we can use extremerc or tam adaptors on this fan.
That would be nice :-)
flylow2011 is offline Find More Posts by flylow2011
Old Dec 20, 2013, 07:33 PM
JGuilty13's Avatar
Joined Nov 2005
Ill be snagging one of these for sure.....cant beat that sound. I originally had the HK DPS 10-blade unit installed in my Freewing F15, but the unit was just too heavy, so I took it out and put the stock 4s system in (and love it). This will obviously be lighter than the DPS, so this is going to be a good option for me.
Old Dec 20, 2013, 09:52 PM
Joined Oct 2013
Yea I just bought 2 for my Dynam Twin Turbo jet... It was already pushing 1.77kg of thrust stock on 4s and high timing on esc's... I'm hoping to get the sound and another 200 grams or so of thrust to put me over 2.0kg.... Now that would be cool!!!! Plane only ways 1.4kg fully loaded....
Old Dec 20, 2013, 09:54 PM
Joined Nov 2011
yeah, everything nowadays is getting heavier and
consuming more energy :-)
Old Dec 21, 2013, 05:18 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Nice find!
snagged 2 for my 48" SU-39. always wanted to upgrade to high blade count fans but the dps units where to heavy. These may just fit the bill, im worried of motor dia.
D_FAST is offline Find More Posts by D_FAST
Old Dec 21, 2013, 05:56 AM
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
I purchased one of these for my Stinger 64 and the smaller collet is indeed 3.17. HobbyPartz has these in stock at a decet price here
http://www.hobbypartz.com/53p-20018.html
The motors they stock are here. Looks like I am going to try 4300kv on 3s
http://www.hobbypartz.com/75m92-duct...ProductReviews
bps is offline Find More Posts by bps
Old Dec 21, 2013, 03:26 PM
Joined Nov 2011
so what is the size of the other collet? 8mm?
what is the size of the motor housing? 28mm or????
if it is 28mm then this 2700KV motor would be a good choice for
4S and high power, the motor weight is only 80gr.
http://www.hobbypartz.com/75m96-ducted-2220-2700.html
Old Dec 21, 2013, 08:03 PM
bps
bps's Avatar
Indianapolis, IN
Joined Apr 2001
The fan comes with two collets, one is 3.17mm and the other is 4mm. The fan motor mounting area is 20.8mm I.D. My fan and spinner combination is out of ballance a lot. This will give me something to work on while I wait for the motor.
The above HobbyPartz motor is a 26mm wth a 19.9mm c-face (mounting flange).
Old Dec 21, 2013, 09:12 PM
Joined Nov 2011
thanks for the info :-)
I have little experience with balancing the fan.
I just bought the factory static balanced fans from wemotec, het
and use them without the spinners, with inrunner motors to avoid
out of balance issues. Some are great, some are OK .
here is a video flyer balanced the bell of his outrunner motor.
It is neat though
How to precision balance an outrunner motor bell (3 min 46 sec)
For Sale Change Sun 70mm 12blade fan Grandstand Aircraft - General - Miscellaneous (FS/W) 1 Nov 03, 2013 10:23 PM
Sold Change sun 10 blade edf units hi2nr Aircraft - Electric - Jets (FS/W) 4 Dec 13, 2012 10:34 AM
Wanted Change sun 10 blade fan unit beercandan11 Aircraft - Electric - Jets (FS/W) 3 Jul 27, 2012 10:31 AM
Sold Change Sun 10 Blade/Castle Lite 100a/Eflite BL15/3200kv Motor fastjetadic Aircraft - Electric - Jets (FS/W) 3 Jul 19, 2012 09:46 PM
Sold 70mm Change Sun Eflite 3200kv Habu Fan TreeFlyer Aircraft - Electric - Jets (FS/W) 8 Feb 29, 2012 03:28 PM
