Old Oct 04, 2008, 12:47 PM
LaurenceGough is offline
Find More Posts by LaurenceGough
LaurenceGough's Avatar
Reading, UK
Joined Sep 2007
Question
What dremel tool do you use?
Hey guys, need to cut a motor shaft today and I realised I have no metal cutting tools at all...
I have a dremel (not proper make) but the chuck broke and I've lost all the accessories...
I would like a decent Dremel (proper make I presume is the best).
I was looking at the Dremel Stylus, seems really good, about 60 pounds so not to bad. Any things I should be aware of?
Cordless and has a decent battery/charging station. Looks comfortable too, unlike those round long ones.
I take it will cut through 4mm or so motor shafts?
Looking to order tomorrow night.
Thanks for any advice!
LaurenceGough is offline Find More Posts by LaurenceGough
Old Oct 04, 2008, 01:25 PM
66tbird is offline
Find More Posts by 66tbird
To many projects
66tbird's Avatar
USA, AZ, Litchfield Park
Joined Aug 2004
Most cordless versions (I have a Stylus) gets hot and are fairly weak. Fine for small jobs and with a cut-off wheel (soaked in CA) would cut a 4mm shaft. Do it three times in a row and you'll need a corded Dremal. The stylus does hold a charge for months if not used. Great for the flight box. Small jobs its fine, any job over five minutes and I use a corded because the Stylus gets to hot to handle.
66tbird is offline Find More Posts by 66tbird
Old Oct 04, 2008, 01:33 PM
Reading, UK
Joined Sep 2007
Thanks tbird!
I've been thinking, I have a corded drill which is a powerhouse, even though it's not a proper make it works well but only drills.
I think the most I would ever use a Dremel for would be to cut steel shafts, I mean I tend to make do without a Dremel until I get to cutting something tough...
I guess I would also be cutting hardened 3mm screws (just trying to think of all the things I would be cutting).
I mean would it struggle much with the 4mm-5mm steel shafts for motors, because that's really what I'm buying it for mostly, but I don't know I might love it and use it even for little sanding jobs on plastic.
(what do you call tough? ) So it just heats up and looses power?
I suppose the accessories (cutting disks etc) will be the same as for the corded more powerful dremel versions?
I remember my old no-name Dremel tool, the cutting disks used to last hardly any time...
Thanks once again!
Edit:
No way... It's the same price in dollars... half the price....
Haldor what CAD program do you use! thrmaln Electric Ducted Fan Jet Talk 53 Apr 27, 2003 09:27 AM
Took The Leap & got New Computer with Win XP - What Burning Software do you use? mrebman Life, The Universe, and Politics 3 Jan 17, 2002 08:16 PM
What Model Servos do you use on your Duskstik? mrebman Parkflyers 1 Nov 02, 2001 02:17 PM
What Battery Packs do you use in the Teddy? mrebman Foamies (Kits) 7 May 07, 2001 10:30 PM
What battery charger do you use? jdmartin8 Parkflyers 11 Apr 21, 2001 05:49 AM
