Old Jan 19, 2003, 12:55 PM
himilecyclist is offline
Find More Posts by himilecyclist
Salt Lake City
Joined Jan 2003
Wingo Wing Failure - Ouch!
On the third perfect flight of my Wingo this morning, disaster struck. I put the plane in a steep dive and then pulled up, planning to do a loop. Well, the stress split the wing right down the center. Needless to say, I came home with a box of parts. Nothing some glue and time won't fix, though.
My question: I've heard of folks reinforcing foam wings. I guess that must be a good idea! How is the reinforcing done? What material is used?
Thanks!!
himilecyclist is offline Find More Posts by himilecyclist
Old Jan 19, 2003, 01:06 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Another satisfied Wingo user
Sounds like one of your wing supports came loose.
You can tape the parts with "thin" packaging tape like they use for the JKAerotech planes like the T-52. This tape is quite a bit thinner (read lighter) than the stuff you buy at Walmart, etc. ZAGI tape will also work. Overlap each spanwise length of tape by about 1/2" starting the first strip at the trailing edge. Better yet, read the T-52 taping procedure.
http://www.jkaerotech.com/
Goto "Instructions and Tech Stuff", than to T-52 building Instructions.
The WINGO fuselage is generally what comes apart.
By the way, the T-52 is nearly indestructible.
hoppy
hoppy is offline Find More Posts by hoppy
Wing failure - pilot error or manufacturer fault? Peter Young Electric Plane Talk 23 May 03, 2003 06:24 AM
What other plane with Soarstar/Wingo wing? Quacker Foamies (Kits) 4 Dec 02, 2002 10:38 AM
Securing Wingo wing Richard Emholtz Parkflyers 3 Aug 05, 2002 08:58 PM
warped wingo wing starman Foamies (Kits) 2 May 24, 2002 01:53 PM
hs225bb failure... ouch! jaggies Electric Heli Talk 0 Dec 16, 2001 01:06 PM
