Old Nov 14, 2014, 08:01 PM
brand_in is offline
Find More Posts by brand_in
Joined Nov 2014
maiden flight, tandem wing, dual edf instability
can someone help me trouble shoot this scratch built plane and tell me how tune/fix it
basically once it took off it kind of went to the left and throughout the flight it continued to turn left, i had my trim maxxed out for a right hand turn but it still wants to go left
is it my cog?
wing rock?
torque roll?
any ideas would be helpful thanks!!
here is the youtube link
Maiden Flight (2 min 7 sec)
brand_in is offline Find More Posts by brand_in
Last edited by brand_in; Nov 14, 2014 at 08:03 PM. Reason: cant see my video originally attached
Old Nov 14, 2014, 08:23 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
It looks like it might be a little tail heavy , try moving the battery forward a little .
Do you have both motors' ESC's going into the receiver on a Y harness ? It could be that the right motor is putting out a little more thrust than the left motor , which would cause it to turn left . You can set up a mix with your throttle and rudder channel , then the rudder stick ( and trim ) will give you variable thrust between the two motors .
Al
balsa or carbon is online now Find More Posts by balsa or carbon
Old Nov 15, 2014, 01:12 AM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
Also, check if the left and right wing (wings) are parallel by looking at the plane from the front.
djacob7 is offline Find More Posts by djacob7
Old Nov 15, 2014, 01:26 AM
brand_in is offline
Joined Nov 2014
thanks guys
yes both motors ESCs are hooked to a "y" harness, i will check if one of the motors is stronger, i should probably mix some rudder into the motors anyway.
I will definitely check the wings more closely, when i taped them it seemed to add some dihedral but maybe i didn't tape them quite the same and one has more than the other :/
Old Nov 15, 2014, 07:31 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Some actual pictures of the model would help, the video shots are too far away to really see what is happening and why.
It looks like it is more a lifting body model, than a conventional model which has the wing area greater than the body area.
Short span models can be prone to roll, (dutch roll ?)
Have you used one of the canard cg calculators ?
eflightray is offline Find More Posts by eflightray
Old Nov 15, 2014, 09:58 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Although we know how you guys love LOUD rock , it might be better to actually hear the motors to better help determine what’s happening ... Being Blasted whilst thinking just makes me want to run away ...
gpw is offline Find More Posts by gpw
Old Nov 15, 2014, 11:25 AM
Joined Aug 2010
Looking at the video , when your wife/girlfriend releases the plane it seems to YAW to the left , which makes me think it's differential thrust more than torque roll - although a narrow wingspan is more sensitive to torque roll .
Old Nov 15, 2014, 12:22 PM
djacob7 is offline
Joined Jan 2009
Unequal dihedral isn't that critical - it will just cause the plane to fly in a slight tilt. What I meant about the wings being parallel seen from the front is shown in the pic...
Old Nov 15, 2014, 03:54 PM
nuteman is online now
Find More Posts by nuteman
Joined Apr 2013
It could be any of the above (or a combination of all), plus some significant build asymmetry. Like maybe one of the winglets is not perfectly parallel to the center-line of the aircraft while the other is - generating a significant pull to the left. Or maybe there's unequal wing twist, causing a really strong difference in lift between the two wings (fore or aft set) such that you get a really strong left rolling tendency. Also, does it do the same in a power off glide? If yes, that would rule out differential trust issues. Also, are the motors perfectly parallel to the center-line of the aircraft? In any case, just for experimentation sake: Try making your control surfaces much larger so that the trim to the right will have a heftier effect. If that helps to get it flying straight in a power off glide, then you are almost certainly looking at a large asymmetry issue.
In the plane below I had massive asymmetry (very warped foam). I just mechanically set the "neutral" position such that one elevon was much higher than the other (via adjustment of the pushrod length from the servo to the control arm). Not very elegant, but expedient
Flight of Vectored Thrust Delta with takeoff landing (1 min 40 sec)
nuteman is online now Find More Posts by nuteman
Old Nov 16, 2014, 12:57 AM
brand_in is offline
Joined Nov 2014
here's some pictures, the wings are parallel from what i can tell, there did seem to be some differential thrust so i mixed in some rudder and will be able to trim it in the field, also going to move cog forward, hopefully take it out again tomorrow morning wish me luck! and thx for your input
Old Nov 16, 2014, 03:03 AM
Joined Aug 2010
Let us know how it turns out .
Is it your own design ? Here is one of my favorite tandem wing planes - it has control surfaces on the front wing as well as the back wing , all mixed as elevons for a fast roll rate and quick loops .
RC Flying Car Thing! (3 min 12 sec)
Old Nov 16, 2014, 06:52 AM
flypaper 2 is offline
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Excellent video. Thanks!!
Are plans available for it.??
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Nov 16, 2014, 02:05 PM
Joined Aug 2010
Gord.
I don't know if RC SuperPowers still sells plans , here's his website
http://www.rcpowers.com/
and here's his email
http://www.rcgroups.com/forums/sendm...member&u=73210
Discussion First ever outdoor R/C flight + Maiden Blade 350 flight Slammr Multirotor Talk 0 Sep 24, 2014 11:17 PM
Video A-10 Warthog 70mm EDF Maiden Flight budkeywest Electric Warbirds 1 Jul 13, 2014 09:52 PM
Discussion EDFs in real flight: E-Fan trainer dual 60kW EDF mopetista Electric Ducted Fan Jet Talk 0 May 24, 2014 05:58 AM
Build Log Hover-EZ ... a tandem wing - (was bi) tricopter hybrid ** Maiden Flight** leadfeather VTOLs 127 Mar 07, 2012 09:32 AM
