Old Apr 18, 2014, 10:58 PM
wilf370 is offline
Find More Posts by wilf370
rookie
wilf370's Avatar
Canada, SK, Saskatoon
Joined Dec 2012
engine power
So im thinking of comparing power on some of my glow engines. my thoughts are if I put a prop on the engine run it wide open and see what rpm it turns. then put the same prop on a different engine and compare rpm. this is on 40 to 46 engines old and new?
Wilf
wilf370 is offline Find More Posts by wilf370
Old Apr 19, 2014, 06:19 AM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Not conclusive:
You can get a decent .45 2 stroke to run 16000 RPM with a 10 x 6 for example, but a 1.20 fourstroke with that same prop will not reach 16000 RPM.
What I am saying is: two engines that are designed to develop their respective peak power at too different RPMs, cannot be effectively compared by this method.
It would be the same as comparing a 100 bhp racing bike engine with a 100 bhp tractor engine, and saying that the tractor engine is much slower, therefore MUST be much weaker....
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Apr 19, 2014, 07:36 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think he meant to compare some .40 and .46 two stroke glow engines to each other. So if he ran the same 9x7, 10x6 and 11x6 propellers on all of the engines and recorded the results, using the same fuel, then he could compare the results to see what happened. It seems fairly reasonable to me.
But you are correct in that one has to be careful as to what they are comparing though.
earlwb is offline Find More Posts by earlwb
Old Apr 19, 2014, 07:51 AM
kimchiyuk is online now
Find More Posts by kimchiyuk
kimchiyuk's Avatar
United States, NY, Eldred
Joined Jun 2012
Are you doing this just for fun? Or are you trying to pick the "best" engine from several you have for a specific application? If it's the latter, than you must also consider weight.
kimchiyuk is online now Find More Posts by kimchiyuk
Old Apr 19, 2014, 08:24 AM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
That is a pretty good comparison. As has been mentioned, other things come into play. It is a good guide. I checked a bunch of motors that way and it gives a good guideline. Some motors are happier at higher rpms, and may not give good numbers on a bigger prop. A 10-6 is a good guide. I found OS LA, TT GP .40's to be in the 11,000 range, and the BB Supertigers and AX to be closer to 14, and 15,000. I am happy with say, my AX .46 because the throttle is so linear and faithful and would sacrifice a bit of top end for that. (it is ok there too though.) Some others stumble and don't have a reliable idle which enters into my choices. Also some motors may wind up a bit more while in the air. Especially with a higher pitch prop and/or a pipe.
aspeed is online now Find More Posts by aspeed
Old Apr 19, 2014, 08:47 AM
The Netherlands
Joined Nov 2009
Not even then: a Rossi for example was designed for FAI fuel, and a K&B typically for 15% Nitro or more.
Hardly likely, a direct comparision on the same fuel is providing an accurate picture....
Brgds, Bert
Old Apr 19, 2014, 11:06 AM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
I tach all my engines with different combos and record the findings along with other data like weight in a journal. Very handy when deciding what engine/prop/fuel combo to use on a particular plane.
jeffie8696 is offline Find More Posts by jeffie8696
Old Apr 19, 2014, 03:03 PM
wilf370 is offline
rookie
wilf370's Avatar
Joined Dec 2012
So i'm building a engine toque dyno. It will measure rpm and thrust. I do not have a clear picture in my head of the linear power band of a propeller. Does anyone here know where I can find some info on that/
Wilf
Discussion Combustion-engine powered RC submarine DerKrawallkeks Submarines 65 Jan 08, 2015 04:11 PM
For Sale 1949-50 1st model Fox Super Power .29 engine nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 01, 2014 08:05 AM
Sold 1954 Fox .19 Super Power engine, NIB nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 08, 2013 07:06 AM
Sold New In Box Evolution 60NX R/C Engine ! The power of a 60 in a 46 sized engine ! shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Oct 27, 2013 12:45 PM
Question Is there such thing as an engine having too much power? walleyehunter34 Engines 20 Oct 24, 2013 08:02 PM
