Old Feb 03, 2014, 06:04 AM
fheanor is offline
Find More Posts by fheanor
Joined Jul 2005
Detachable/portable flying wing with true airfoil: your parkflyer in a "backpack"
Hi all!!
I have build a little portable/detachable flying wing and I would like to share the design with you.
There is nothing new, but I think that some of you will be interested because it can be transported in "standard" backpack, so you can use your bicycle to go to the flying field or park to fly this small piece of foam !!!
I have built two wings;
The first one is bare depron with a thick airfoil, it only weight 126grs ready to fly (except the battery) and it's powered by a 10 grs motor and 6 amp esc.. With a fresh 460mah 3s (add 45grs) and a 5x5 it goes vertical and it glides forever. I've done more than 50flights and it still flies wonderfully
The second version has a thinner airfoil, its powered by a custom wound cdrom motor (8T 21awg wire) and it's powered by a 4s 1300mah battery and 20amp esc. I'ts really fast (about 80mph) and flies like a dream
Both wings have a center section in which all the electronics are installed. The wing sections and center sections are joined by carbon fiber spars and hold in place by neo magnets. Enough talk!! next images and videos are self-explanatory
video
video ensamblaje (0 min 38 sec)
PICS
Description: wing dimensions and balsa airfoil former placement line. The ailerons are not shown but they should measure 4cm wide. Name: 2.jpg
Description: I use poliurethane glue. I'ts a lot lighter than hot glue. We are about to glue the balsa spar which will form the airfoil Name: 3.jpg
Description: Te airfoil it's almost done Name: 5.jpg
Description: airfoil done Name: 6.jpg
Description: we give eought time to cure the glue
Description: This are the carbon fiber rods. the inner rod is 3mm of diameter. The outer rod has an internal diameter of 3,2mm and external diameter of 4mm Name: 8.jpg
Description: We carve the canal where we will glue the outer rods Name: 9.jpg
Description: outer rods glued and neo magnets that will secure the wings Name: 10.jpg
Description: wing detached Name: 11.jpg
Description: attaching the wing
Description: more images of the attaching system Name: 14.jpg
Description: Name: 15.jpg
Description: They are pretty!!
fheanor is offline Find More Posts by fheanor
Old Feb 03, 2014, 07:29 AM
fheanor is offline
Joined Jul 2005
flying video with 4s
GOPR0010 (2 min 24 sec)
Old Feb 03, 2014, 10:25 AM
ttersu is offline
Find More Posts by ttersu
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
Realy funny! Thank's!
Don't forget to share plans!
ttersu is offline Find More Posts by ttersu
Build Log The Fury Flyer- 54" TRUE AIRFOIL FLYING WING(Plans and 35" version!) Bixler13 Foamies (Scratchbuilt) 450 Apr 09, 2015 09:04 AM
Discussion Techone Neptune detachable wings mod??? luislgon Foamy EDFs 1 Mar 09, 2014 09:54 PM
Sold Zagi -XS flying wing. Add your own brushes Motor, EAS and battery $49 + $25 S&H unclegeorge Aircraft - Electric - Airplanes (FS/W) 0 Nov 01, 2013 04:20 PM
Gallery Any interest in a detachable 48" flying wing with AP pod in the middle? Kyle G. Aerial Photography 6 Jan 10, 2012 03:57 AM
Question How you true up your parkflyer wing? kist2001 Parkflyers 4 Sep 01, 2004 08:39 PM
