Old Sep 13, 2013, 03:12 PM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
New Product
New Schuebeler HDS 70mm and 90mm fans
Presented at the Jetpower event running just now in Germany.
News only in German for now
http://www.schuebeler-jets.de/news/3...-impeller.html
Apart from stiff fan blades designed for best efficiency in a broad powerband and low noise, those two 69- and 90mm fans show a very innovative vane/shroud design: The stator made of high tensile aircraft aluminium alloy (providing rigidity and optimum heat dissipation for the motor) is fused together with the unidirectional carbon shroud - allowing for minimal blade gap and high thrust in the airframe.
DS-30-AXI HDS (69mm), price forecast 139 Euro
max rpm: 60.000
max power: 2750 W
max static thrust: 33 N equivalent to around 3.4kg
max efflux velocity: 94 m/s
weight: 54 g
max motor diameter: 28 mm
for 4mm shaft diameter
DS-51-AXI HDS (90mm) price forecast 149 Euro
max rpm: 50.000
max power: 5350 W
max static thrust: 64 N equivalent to around 6.5kg
max efflux velocity: 101 m/s
weight: 107 g
max motor diameter: 39 mm
for 5mm shaft diameter
EDIT: There is a video interview with Daniel Schuebeler himself online now (from the Jetpower event / fair). It's in German, so I'll tell you what's happening (not repeating what is already stated above about alloy stator (black for max heat dissipation) etc):
- first he talks about some changes in the plugs of the HST series, more robust cabling not liable to get unstuck by itself after some use
- 1:49 min: showing the new 215mm fan, the problems he had with the motors are solved, the 10-pole is now running at 90% effiicency, 50V, 300amps...
- 2:28 min: New 6mm silvered plugs, good for up to 700amps (short duration), will not get unstuck
- 3:18 min: HDS fans; long development phase (2,5 years), for the last 2 years very much on his agenda. No compromise in quallity and efficiency at much lower prices. Motor rpm higher than the HST series, so lower load for the (injection molded) fan blades
Neuigkeiten Schübeler-Impeller auf der Jet Power 2013 (7 min 49 sec)
mopetista is offline Find More Posts by mopetista
Last edited by mopetista; Sep 16, 2013 at 09:03 AM. Reason: translated the (preliminary) data sheets from the German website
Old Sep 13, 2013, 06:33 PM
airboss/oc is offline
Find More Posts by airboss/oc
California Style
airboss/oc's Avatar
United States, CA, El Mirage
Joined May 2007
those are the nicest I've seen and they sound great ,very quiet
airboss/oc is offline Find More Posts by airboss/oc
Old Sep 13, 2013, 06:35 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
I can't tell for sure but the blades don't look like the typical carbon fiber....but that should lower the price a bit
Kevin Cox is offline Find More Posts by Kevin Cox
Old Sep 13, 2013, 09:31 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
The blades look injection molded to me. I will look forward to see numbers.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Sep 13, 2013, 09:47 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
I'll get some info from Daniel or Christian on these when they return from Jetpower.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Sep 14, 2013, 03:44 AM
Vienna, Austria
Joined Apr 2007
prices...
they will be available in Europe directly from Schuebeler., or Fantastic Jets
70mm (fan only, for 4mm motors 28mm diameter) DS-30-AXI HDS: 139.00 €
90mm (fan only, for 5mm motors up to 39mm diameter) DS-51-AXI HDS: 149.00 €
Old Sep 14, 2013, 10:45 PM
nighthawk0077 is online now
Find More Posts by nighthawk0077
Joined Oct 2009
Wow those are very impressive numbers, and a Schuebler fan for only $139? Sign me up!
nighthawk0077 is online now Find More Posts by nighthawk0077
Old Sep 14, 2013, 10:53 PM
Mike Warren is offline
Find More Posts by Mike Warren
Not Funny......
Mike Warren's Avatar
Joined Dec 2010
Ah hem.........RTFQ....
That's 139.00 EURO's (and don't forget shipping costs)
About $187 at current exchange rate
Mike Warren is offline Find More Posts by Mike Warren
efflux RC's Avatar
Joined Aug 2009
Nighthawk0077,
Not sure if your in the US, but that's 139 Euros......$184.97.
I left word with Christian about getting the 70 and 90mm units in house.
Thanks for posting the specs in English, Mopetista.
Site Sponsor
Old Sep 15, 2013, 11:45 AM
Vienna, Austria
Joined Apr 2007
my pleasure, and not used to get much thx in the threads for this kind of effort I am all the more pleased and linked the video interview with Schuebeler, plus a short story line what's happening, above in post #1:-)
cheers
Clemens
Old Sep 15, 2013, 01:46 PM
efflux RC's Avatar
Joined Aug 2009
cheers
Clemens
I've seen your posts for Shubie and appreciate them.
I've been a "fan" (pun intended) of the HDT units for 5 years, and have used the DS-30, 44 ,and 51-DIA HDT in a number of jets.
The popularity of the HDT series dropped off with the influx of the higher blade count EDFs.
I'm looking forward to the new series, and their price point is quite reasonable for a Schuebeler product.
Gary
Site Sponsor
Old Sep 15, 2013, 03:00 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Beautiful fan!
I know HST is high static thrust and HDT is high dynamic thrust.
Whats HDS stand for?
bmiller is offline Find More Posts by bmiller
Old Sep 15, 2013, 03:04 PM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Wow...look at the pitch, of the blades, near the hub! Like the CS rotors.
Fuzz
St. Martin is online now Find More Posts by St. Martin
Old Sep 15, 2013, 09:07 PM
mongdex is offline
Find More Posts by mongdex
If it flies, I like it.
Thailand, Sing Buri, In Buri
Joined May 2012
Just what I've been looking for a super fast efflux 90mm.
Now waiting for it to be available near me.
mongdex is offline Find More Posts by mongdex
Old Sep 15, 2013, 09:17 PM
California Style
airboss/oc's Avatar
Joined May 2007
Originally Posted by bmiller View Post
Beautiful fan!
For Sale Fans - 50mm, 60mm, 70mm, 90mm used and new Kenneth Henius Aircraft - Electric - Jets (FS/W) 8 Mar 17, 2012 11:56 AM
Sold Schuebeler DS51 Carbon 90mm fan, HET motor and Hacker 77A ESC Sul1 Aircraft - Electric - Jets (FS/W) 3 Jul 15, 2010 05:19 AM
Discussion New Metal Ducted Fans for 70mm to 90mm EDF Jets! nitroplanes Nitro Planes 1 Jun 15, 2009 08:59 AM
Comparing the Ramtec-Byron Fans to the schuebeler 90mm Sluf7 Electric Ducted Fan Jet Talk 15 Oct 24, 2004 08:52 AM
New Schuebeler 90mm Fan Unit Gordon Electric Ducted Fan Jet Talk 99 Feb 10, 2003 12:17 PM
