Old May 08, 2014, 02:47 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
The full size is supposed to be at prime AoA on take off at 20 degrees but actually takes of at less. The tail has a wheel fitted just in case !! not only for take-off but for landing as well......... BA reports that it has never been in contact with runway in all scheduled flights.
My EDF's are actually quite low and I am in danger of scraping them on the ground IF I lift the nose too far... but so far she's managed to leave the ground before it's actually happened.
I do have scrapes on bottom of the nacelles from landings though.
My next project is the TU 144 .. this will be Pusher props .. similar size to my Concorde (1200mm LOA, 600mm span) ..
The prop problems will be there .. but we hope the power will be such that she will 'rocket' down the runway !!
Power is initially to be twin :
Floater-Jet Replacement Motor (AXN-2208-2150)
Specs.
RPM/V: 2150kv
Max Watts: 180w
Max Amps: 20A
Max Volts: 11.1 (3s)
Turns: 16t
Resistance: 0.085Rm
Magnet type: N45SH
Idle Current: 1.52A
Shaft: 3mm
Weight: 44.0g
Suggested Prop: 5x5 / 6x4
using 5x5 or 5.5 x 5.5 props ... on 3S but with 4.75 xx 4.75 I could likely go 4S..
OR :
my twin 3200kv motors of my twin Parkjet .. with 4.1 x 4.1 props and 4S ..
Nigel
solentlife is offline Find More Posts by solentlife
Old May 08, 2014, 03:12 AM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
TU-144 That's a build I look forward to Nigel!
demondriver is online now Find More Posts by demondriver
Latest blog entry: Very big RC MD-82 & MD-90
Old May 08, 2014, 03:14 AM
Up-Out-&-Gone
Joined Mar 2007
Lionel. . . What's the status of your Concorde. . . . . What conclusions have you come to?
Old May 08, 2014, 03:56 AM
solentlife's Avatar
Joined Jan 2010
Similar story as what prompted ny Twin EDF Concorde .. part of a Scratchbuild Comp on Wattflyer ..
http://www.wattflyer.com/forums/showthread.php?t=73244
Only trouble is I'm stuck in Crimea .. Visa running out .. no way to travel out .. so have no idea when I will get back home again ...
Nigel
Old May 08, 2014, 10:25 AM
Blendedwing is offline
Find More Posts by Blendedwing
Blendedwing's Avatar
Joined Jun 2011
... just to fill the time, while Lionel is organizing the next step, here is my version in scale 1:48 .
You will not be
surprised to hear :
it does not sport
any landing gear
http://rcflights.com/video/Concorde_Mk5-2.wmv
Blendedwing is offline Find More Posts by Blendedwing
Old May 08, 2014, 11:59 AM
Michael V is offline
Find More Posts by Michael V
Michael V's Avatar
United States, CA, Torrance
Joined Apr 2012
Originally Posted by Blendedwing View Post
Hi Michael,
I do have some experience with Concorde, if you see my "Family development" video you will notice that I have experimented with a large number of models, from chuck gliders to 1:48 scale models.
I second many of your, and Nigel's, observations:
- it can parachute itself down
- it is very sensitive to CoG Position and elevons deflection
- like all delta's it bleeds speed during turns
- negotiating take off and landing, on an undercarriage, is the most complex part of the airplane
As a consequence it is a big challenge the one you have taken on: building it as a sloper.
The benefit with a sloper is that you do not to have to worry about the undercarriage.
Awesome, thanks.
I love your Concorde series and how it flies, great stuff.
OK, on everything else you confirm what I've found so far. At least I don't have to figure the take off landing part :-)
And yes it always seems like I need more speed, but I can't get it (no motor) so the solution is more weight, but so far it hasn't been great success.
Yes so it looks like I won't be taking the challenge of a Concorde as a sloper Dommage!
Danke sehr!
Michael V is offline Find More Posts by Michael V
Old May 08, 2014, 03:23 PM
carguy1994ca is online now
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
You will not be
surprised to hear :
it does not sport
any landing gear
Awesome ! Loved the landing A very technical model to build and fly, I'm learning a lot on this tread.
carguy1994ca is online now Find More Posts by carguy1994ca
Old May 08, 2014, 06:18 PM
Concordefan2 is offline
Find More Posts by Concordefan2
Concordefan2's Avatar
Joined Jun 2013
Wow!!!, you built a beautiful little Concorde ' s model and let me tell you, the roll you did, is scale!!. I mean Capt, Brian Whirlpol has rolled AF's Concorde in flight during one of many test flights......
Concordefan2 is offline Find More Posts by Concordefan2
Old May 08, 2014, 06:30 PM
Joined Jun 2013
http://m.youtube.com/results?q=rolling%20Concorde&sm=12
Old May 09, 2014, 04:23 AM
Joined Jun 2011
Great video at that link,
thank you Concorde2 !
Old May 09, 2014, 07:31 AM
Up-Out-&-Gone
Joined Mar 2007
+1 Sweet Bird!
Old May 20, 2014, 02:35 AM
Joined Jun 2013
Doesn't this looks familiar!....
Old May 20, 2014, 03:44 AM
Up-Out-&-Gone
Joined Mar 2007
It looks like it's at an RC trade convention somewhere.
Discussion Scratchbuilt foamboard Concord ecworks Foamies (Scratchbuilt) 3 May 14, 2013 04:36 PM
Sold HobbyTown Concord, CA Swap Meet - Sun 4/28 skybyfly Non R/C Items (FS/W) 3 Apr 29, 2013 10:27 AM
Build Log Scratchbuilding a Concorde Jet - Photos, Info and Stuff metroflyer Foamies (Scratchbuilt) 5 Jan 13, 2008 02:30 AM
