Old Mar 10, 2013, 08:40 PM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
I have a 55 in a clasic trainer and its the first plane that gets put in the car . Dont worry about anyother thing just get the 55 and you wont be sorry . In my experience its a very good engine . Cheers the pope
the pope is offline Find More Posts by the pope
Old Mar 11, 2013, 11:17 AM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
I particularly like the sound and smoothness of the idle on the .46 and .55. I have never heard that on any other motor in my collection (pile) They seem quite powerful for a hobby grade motor too. As far as power figures are concerned, people expect idle of 2,000 and peak power of 28,000 rpm and max rpm of 32,000rpm to be achievable and use them for comparison to other motors. That is only numbers. I would just use them for selecting a prop really. Like car motors before 1971 with peak brake hp (bhp) and then later the SAE net HP, and now all the dyno rear wheel HP. It is all apples to oranges. Before 1971 they took off the alternators mufflers and misc. accessories to get the biggest #'s they could.
aspeed is online now Find More Posts by aspeed
Old Mar 11, 2013, 02:22 PM
Machzx is offline
Find More Posts by Machzx
Joined Nov 2012
Dar do you have hp numbers for a 55ax with the Jett pipe ?
Just curious as I have that setup in a box to go in a primo 40
Thanks Ed
Machzx is offline Find More Posts by Machzx
Old Mar 11, 2013, 07:54 PM
Desert flier is offline
Find More Posts by Desert flier
Desert flier's Avatar
Australia, SA, Morphett Vale
Very interesting I was going to ask whats the difference between a 46 size engine and a 52 ASP as I am using a trainer for a tow plane and would like a little more pull for a slighttly larger glider. my conclusion is a 52 will have just that little bit more for practicaly the same weight
Desert flier is offline Find More Posts by Desert flier
Old Mar 12, 2013, 09:55 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Thanks Ed
Ed,
The JettStream tuned muffler will fit onto the OS.55AX and the two will work pretty well together.
However, I believe the boost will be to a lesser extent than it is with the .46AX...
It would be very nice if someone participating here , that owns both the JettStream and an OS.55AX, would make the effort to give use some comparative number; the PowerBox Vs. the JettStream, on some usable prop sizes.
If these comparisons could be done also on the OS.46AX, it would be even nicer!
DarZeelon is offline Find More Posts by DarZeelon
Old Mar 12, 2013, 11:23 AM
Canada, ON, Cottam
Joined Jan 2012
I'll take a donation of a Jett pipe and do the tests happily :-) I don't know why the muffler is called a Powerbox, Mine is round inside.
Old Mar 12, 2013, 11:29 AM
DarZeelon's Avatar
Joined Nov 2003
Me too!
Old Mar 12, 2013, 03:05 PM
Machzx is offline
Joined Nov 2012
I have both ill post pics see if they are the same ?
Sold *** Price Reduced *** OS Power Box E-3010 Muffler for OS 46 AX, 55 AX and others modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 08, 2012 09:48 PM
Sold OS Power Box E-3010 Muffler for OS 46 AX, 55 AX and others modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 05, 2012 04:40 PM
Discussion OS .46 SF, OS .46 FX, or OS.55 AX with Tuned Pipe Nikolizer1 Engines 1 Feb 12, 2009 10:58 AM
Wanted Pitts side mount muffler for OS 46/OS 55 joe0298 - rccrazee Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 04, 2009 01:06 PM
For Sale Tower Hobbies Kaos 40 ARF .40-.46,55" NEW OS FX .46 krosypal Aircraft - Fuel - Airplanes (FS/W) 0 Nov 14, 2007 07:34 PM
