Old Feb 11, 2013, 06:12 AM
lfcwhitman is offline
Find More Posts by lfcwhitman
Joined Feb 2013
Question
firestorm 10t nitro
can anyone help. i've used my car about 10 times so far and came to use it again but it wont start. the fuel line is clear and i've done everything i did to start it the last time i used it.
thanks.
lfcwhitman is offline Find More Posts by lfcwhitman
Old Feb 11, 2013, 07:52 PM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
Check your glow plug. Make sure your igniter is fully charged prime the engine a bit holed your finger over the carburetor it will draw fuel in to the engine.One or two pulls should get it primed. Make sure you put your air cleaner back on.
mredzadventure is offline Find More Posts by mredzadventure
Old Feb 12, 2013, 02:14 PM
Joined Feb 2013
thanks. how do i check the glow plug? and how do i know if it needs changing? I've done everything else.
Old Feb 12, 2013, 02:31 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Take the plug out of the engine and see if it's glowing orange with inserted into the igniter.
wparsons is offline Find More Posts by wparsons
Old Feb 12, 2013, 03:18 PM
Joined Feb 2013
will try that thanks. if it glows orange does that mean its ok or does it mean its worn out?
Old Feb 12, 2013, 04:01 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You want it glowing bright orange.
Old Feb 14, 2013, 08:45 AM
Joined Feb 2013
tried this and it only glowed orange for a few seconds then died. do you think i need a new plug or a new igniter?
Old Feb 14, 2013, 12:09 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
How's the battery in the igniter?
Old Feb 15, 2013, 08:23 PM
USA, MI, Hastings
Joined Jan 2007
I would say the igniter battery is going plugs usually work or they don't
Old Feb 17, 2013, 04:55 AM
Joined Feb 2013
ok. tried a new igniter and it glowed orange. car still wont start though.
Old Feb 17, 2013, 08:36 AM
USA, MI, Hastings
Joined Jan 2007
Try putting a little fuel directly in the cylinder and see if you can get it to fire it sounds like you not getting fuel.
Old Feb 18, 2013, 01:50 PM
sweakyboot is offline
Find More Posts by sweakyboot
plane wrecker
sweakyboot's Avatar
United States, NH, Nashua
Joined Jan 2012
is the car priming itself? If not then you might have a fuel system issue or you could blow into the vent line to prime it. Also the top of the piston might be dirty and need a wiping down with a paper towel. Just a few I've come across.
sweakyboot is offline Find More Posts by sweakyboot
Old Feb 18, 2013, 02:11 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Easiest way to prime is to take off the air filter, put your finger over the carb and turn it over a few times until you see fuel flowing through the line. Put the filter back on and fire it up.
Old Feb 20, 2013, 02:01 PM
Joined Feb 2013
ok thanks. will try these things and get back to you!
Help! Buy the flux set for my firestorm 10t or buy the firestorm flux Tom1996 Car Talk 3 Aug 11, 2012 07:06 AM
Discussion E-firestorm 10T mamba heat question Zero3803 Off-road Cars 0 Aug 04, 2008 12:30 PM
Discussion nitro firestorm 10t converted to electric. greenman11 Electric Power Cars 0 Mar 26, 2008 07:58 PM
Discussion HPI E-Firestorm 10T shaun123 Off-road Cars 0 Nov 21, 2007 10:59 AM
