Old Jan 02, 2013, 01:50 PM
wbuttry is offline
Find More Posts by wbuttry
wbuttry
sikeston mo
Joined Apr 2009
quick question
Hey guys i got a 48 inch epp flying wing i wanna bunge launch it off the catapult. And i'm trying to determine where is the best place to put the wood plate and and launch peg at. Some say the cg and others say toeward the leading edge .Your thoughts would be very helpful thank you in advance for your help...
wbuttry is offline Find More Posts by wbuttry
Old Jan 02, 2013, 02:04 PM
dephela is online now
Find More Posts by dephela
the flying is good
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
Definitely towards the LE!
dephela is online now Find More Posts by dephela
Old Jan 02, 2013, 02:11 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Depends on what kind of a launch you want.
If you want a zip launch, low and fast where you turn speed into altitude, then you place it near the nose. This is common for slope gliders.
If you want a higher, slower launch, like a regular sailplane launch, then you put it near the CG.
On my Zagi 3C slope glider flying wing I put a plate with a blind nut near the front, under the battery and another near the CG under the receiver.
I pick the launch based on where I put the hook.
aeajr is offline Find More Posts by aeajr
Old Jan 02, 2013, 02:53 PM
wbuttry is offline
wbuttry
sikeston mo
Joined Apr 2009
exactly what i got it is a zagi i think the nose is where i would really need to put it aeajr that i thinkis also the best spot i want a zoom launch dephela that cinches it nose is where it goesthen thank you guys for your input.....
Old Jan 02, 2013, 03:10 PM
BigSwede is offline
Find More Posts by BigSwede
Ninja Master
BigSwede's Avatar
United States, CA, Thousand Oaks
Joined Feb 2007
Don't put the hook right on the nose. You'll end up launching your plane right into whatever your bungee is anchored to. I've done quite a bit of bungee launching wings, and the best spot I found is about halfway between the LE and CG. It will zoom your plane clear of any obstacles on the ground. Great fun.
BigSwede is offline Find More Posts by BigSwede
Old Jan 02, 2013, 04:17 PM
atmosteve is offline
Find More Posts by atmosteve
Joined Nov 2007
^ I'll confirm what Big Swede has said, after playing around myself over the years with a few types of chevron combat wing type foamies. It also depends a little how you like to balance your wing and the aileron reflex you give it, but a hook point halfway between the nose and cg point is the very best place to start when you are trying this for the first time. Then you can tune it from there to your liking and best results.
At best only half listen to advice you get off the internet.
atmosteve is offline Find More Posts by atmosteve
Reply With Quote  (Disabled)
Old Jan 02, 2013, 04:20 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
My forward attachment point is about 1 1/2 to 2 inches back from the point of the nose. It launches low and fast. As they said, don't actually put it in the nose or it won't climb at all.
Old Jan 02, 2013, 09:22 PM
wbuttry is offline
wbuttry
sikeston mo
Joined Apr 2009
1 1/2 to 2 inches got it do you think i need to re inforce the wing a tad bit it isnt gonna be a full power launch at all here is what i wanna do
RiteWing TL 50 Bungee Launch (2 min 5 sec)
Old Jan 02, 2013, 10:26 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
In the photos below you will see two compartments along the center of the wing.
The forward one is where the battery goes. Under the battery is a piece of 1/16" ply that is the size of the entire battery area. Through that I placed a blind nut that finishes flush with the bottom of the foam. Then another pice of 1/16" ply on top and then the battery.
Behind that is the receiver area, over the CG. Same arrangement there with the blind nut a bit forward of the CG.
I can screw the hook into either blind nug and the top ply prevents it from screwing in far enough to touch the batter or the receiver.
Blind nut puts pressure on the ply which spreads it out over the foam. Never had a problem.
Old Jan 02, 2013, 10:32 PM
wbuttry is offline
wbuttry
sikeston mo
Joined Apr 2009
i'm gonna give it a try looks like it will work fine do i need to reenforce the plane any for that type of launch?
Old Jan 02, 2013, 10:40 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Not really. Just make sure the foam under those compartments is solidly attached. If it was cut out, glue it back. Then cover that area with reinforced tape overlapping onto the surrounding foam by at least an inch. Then put on your normal tape or heat shrink covering. Then go fly!
Old Jan 03, 2013, 12:38 AM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
We did this many times and kept pushing the limits of the foam wings. We kept adding more and more rubber and getting insane speeds until the wings fluttered so bad you thought the ship was going to explode. So what do you do then? Take a WW Raider and cover it entirely in extreme tape. Yep flutter that to. Last year a friend fluttered a raider covered in 10mm new stuff while DS'ing a ridge. TOO MUCH FUN
davidjensen is offline Find More Posts by davidjensen
Old Jan 03, 2013, 04:29 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Next you cover it with glass or carbon and you no longer have a foam wing but a composite wing.
Discussion Quick Question on SkyFun Jet DJO Pusher Prop Jet Models 2 Mar 21, 2012 03:26 PM
Discussion Quick question about keychain cams. Kawi Aerial Photography 0 Mar 12, 2012 11:59 PM
Question Quick question for AIO/sensor board placement Physics_Dude Multirotor Talk 1 Mar 12, 2012 10:56 PM
Discussion Quick Noob question about ESCs Terrier Multirotor Talk 5 Mar 10, 2012 12:07 PM
Discussion Quick question: GCP servo aileron/elevator andrewho83 Micro Helis 2 Mar 08, 2012 12:34 PM
