Old Aug 24, 2012, 05:06 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Landing gear truss, shocks, whatever?!
Long story short. 40 sized Nitro has an aluminum gear on it. Its your basic 1/8" pre bent cheap aluminum. It is quite flexible and.....
I put a little extra horsepower in it and swing an 11" prop with little ground clearance. Somehow often the prop strikes the ground and quits. Either I cant land for or the gear is bowing and digging the prop into the turf.
I was looking for ideas on putting like wires with springs... like on a cub. Something to stiffen it up.
But the search key is so vague, well needle in the haystack. Anyone know of a good article or two?
UlteriorModem is offline Find More Posts by UlteriorModem
Old Aug 24, 2012, 06:08 PM
aero104 is offline
Find More Posts by aero104
Support Your Local Hobby Shops
aero104's Avatar
Nashville, TN
Joined Feb 2005
aero104 is offline Find More Posts by aero104
Old Aug 24, 2012, 08:57 PM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
You might consider evaluating these for figment on your plane
http://www.cublandinggear.com/
I bought the smaller unit sized for a Multiplex Fun Cub. Very well built.
ltc is offline Find More Posts by ltc
Old Aug 24, 2012, 09:24 PM
scrubmonkey is offline
Find More Posts by scrubmonkey
Australia, QLD, Booyal
Joined Aug 2011
Bicycle spokes between them. Fit one either end, in the middle wrapp with copper wire and solder. Garuntee it will stop the gear from bowing at any point
scrubmonkey is offline Find More Posts by scrubmonkey
Old Aug 25, 2012, 03:48 AM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
Why not just fit some bigger wheels?
MCarlton is offline Find More Posts by MCarlton
Old Aug 25, 2012, 10:07 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Almost what scrubmonkey said. Bicycle spokes, but if you buy them from your local bicycle shop, when will cut them the the length you specify, then you can arange them like the pictures, and use the "nipple" to tighten them up.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Aug 25, 2012, 03:00 PM
Joined Aug 2011
All good ideas thanks. I am actually going to fit a little bigger wheels on it see if that helps then maybe the spokes. Bet they sing when your ripping.
Sold Couple sets of wheels and landing gear pieces for foam planes and whatever you need . MiG-3 Reno Rocket Aircraft - General - Miscellaneous (FS/W) 5 Mar 30, 2012 03:02 PM
Sold Landing gear set. Shock Absorbing kayvannouri Aircraft - Electric - Airplanes (FS/W) 1 Mar 28, 2012 06:41 PM
Shock Flyer landing gear upgrade :) mothflyer 3D Flying 11 Mar 07, 2005 02:47 AM
SlowStick Landing Gear Mod: Shock Absorbers CloudyBright Aerial Photography 12 Mar 05, 2005 08:36 AM
Shock absorber for rigid landing gear Red Baron 47 Parkflyers 3 Jan 19, 2002 07:45 PM
