Old May 01, 2012, 03:03 AM
DPkiller is offline
Find More Posts by DPkiller
DPkiller's Avatar
United States, TX, Lindale
Joined Mar 2012
Universal Charging Leads.
I've been looking around for charging leads.
I've found you you can ether buy a Octopus looking thing (8 in 1) or just a simple 1 type of end design.
So I thought I should make Universal Charging Lead's for (EC2,EC3,EC5,Deans, and others.)
Starting with 4mm Gold plated end's with about 12" of 14awg wire to a PA45 connector, then Another PA45 connector with about a 1" 14awg wiring to (EC2,EC3,EC5,Deans, and others.)
Is this something that would work?
PA45's
DPkiller is offline Find More Posts by DPkiller
Old May 01, 2012, 07:36 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
You can make a multiple harness with as many connector combinations as you like. Just make sure you do not have any exposed pins on any of them. Or if you do, make sure you protect them from shorting.
tacx is offline Find More Posts by tacx
Old May 02, 2012, 06:24 AM
startazz is offline
Find More Posts by startazz
RC plane addict ;-)
startazz's Avatar
United Kingdom, England, Norwich
Joined Aug 2008
Would be a lot easier just buying them but if you can't find what your looking for sure it will work as long as you do what tacx says.
But this is one of the better ones that i found from Hobbyking.
http://www.hobbyking.com/hobbyking/s...apter_Set.html
startazz is offline Find More Posts by startazz
Old May 02, 2012, 10:28 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
I.M.O these may seem simpler, but they are big and clunky, and you have the risk of the exposed ends of other terminals touching, I would go with seperate charge leads and buy/make them as you need them
keithy4129 is offline Find More Posts by keithy4129
Old May 02, 2012, 10:45 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
I question why anyone would need all those connectors available. I simplify things by using a single battery connector, Deans, but you could use any one of several. So I see the need for the primary battery connector, the micro connector found on 1S batteries, a barrel (Tx)connector, and a receiver battery connector.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old May 02, 2012, 02:09 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Most of my batteries use Deans Ultra connectors, so my charge leads are that way too. But I then have short Deans Ultra to Micro Deans, Deans Ultra to Tamiya, Deans Ultra to Anderson Powerpoles, and Deans Ultra to servo socket extensions for the rare times I need to charge something else such as my mini coaxial heli, or a receiver pack. I just feel that's more convenient, and safe, than having a multi-headed lead.
abenn is offline Find More Posts by abenn
Old May 03, 2012, 12:12 AM
DPkiller is offline
DPkiller's Avatar
Joined Mar 2012
Thanks for the inputs guys.
I decently hate the look of the multi charging cord.
I will by ether tonight or tomorrow make my list of supply's and order stuff to build
12 charging cables. With 4 of each ends. (EC2,EC3,Dean's,HXT,HT60,Traxxas,Tamiya, Mini Tamiya, JST Male?)
Am I missing any "important" adapters? (As far as I know ive only seen 1 kind of deans.)
Old May 03, 2012, 01:59 AM
abenn is offline
Joined Jul 2004
Originally Posted by DPkiller View Post
... Am I missing any "important" adapters? (As far as I know ive only seen 1 kind of deans.)
Deans also do a micro plug http://www.wsdeans.com/products/plugs/micro_plug.html, which is what I use in my micro helis instead of the more-usual JST.
Old May 03, 2012, 05:44 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
PA45's
I am doing this for many years now. I have a number of "main" leads with MPX plugs, that also fit for my flight packs, and a handful of short adapters for my TXes, the RX packs, and my indoor packs with Micro Deans.
I don't use any other connectors, as I like standardisation.
For my mobile slope charger, I use a cable with 3 different endings though.
Julez is offline Find More Posts by Julez
Sold EC3 to Banana Plugs Charge Lead TGKconnectors Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 08, 2012 02:47 AM
Discussion blade mcpx multi charge lead anyone ? widget2k4 Batteries and Chargers 9 Mar 22, 2012 01:04 PM
For Sale Blade mCP X 6X Parallel Charge Lead motorbro1470 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 26, 2012 09:51 PM
Question How to reduce the charging rate of a USB charging lead? eyemdee Batteries and Chargers 5 Sep 14, 2011 07:34 AM
