Old Sep 27, 2011, 07:44 PM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Question
Turn a flat paint job shiny?
Is there any way to turn a flat paint job shiny? I painted a plane a matt color ... don't like how it looks ... want to make it glossy ... without repainting.
Possible?
Colin
wollins is offline Find More Posts by wollins
Old Sep 27, 2011, 08:13 PM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
I think that's why they created Clear Coat
Guz is offline Find More Posts by Guz
Old Sep 27, 2011, 08:20 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
High Gloss clear will do the trick.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Sep 28, 2011, 01:04 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
If the paint is thick enough you could try an automotive polishing product called ScratchX. It's intended for making scuffs in a car's clear coat go away but I recently ran across a description for using it to shine up a matt finish on the varnish of a rifle stock. So there's a good chance it'll make your flat finish at least semi gloss.
Otherwise it's adding a clear coat.
BMatthews is offline Find More Posts by BMatthews
Old Sep 28, 2011, 10:03 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Matt color usually has a flattening agent (powder) added to it to make it dull, and no amount of polishing will change that. Clear coat is the only solution.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Sep 28, 2011, 08:55 PM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
+1 on clearcoat. Just be aware that it will change the depth of the colour as it adds gloss, so that the colour will seem darker than it is now. Do a trial patch in an inconspicuous area on the model, or on a separate piece to see if you like it. Good luck!
Steve
Steve85 is online now Find More Posts by Steve85
Old Sep 28, 2011, 10:53 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Thanks guys ... someone also mentioned that Varathane gloss might do well over top as well? Opinions?
Colin
Old Sep 29, 2011, 09:50 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"Varathane gloss"
If I'm not mistaken, Varathane comes in two flavors; water based and oil based; watch which one you are using.
Les
Old Sep 29, 2011, 10:00 AM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
I know ... I'm waiting on an answer from the guy on that. (Which version he was talking about)
Colin
Old Sep 29, 2011, 10:42 AM
sscherin is offline
Find More Posts by sscherin
sscherin's Avatar
USA, WA, Kennewick
Joined Nov 2005
Nelsons clear with crosslinker if you have your own spray gear..
Water based, no VOCs and it's fuel proof.
Can also be brushed on..
http://www.nelsonhobby.com/
sscherin is offline Find More Posts by sscherin
Old Sep 29, 2011, 12:42 PM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
So it was the water based that he meant ... now that I have all these options I'm wondering which would add the least weight!
Colin
Old Sep 30, 2011, 09:35 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
"now that I have all these options I'm wondering which would add the least weight! "
Which ever one you apply the thinnest:-))))))))))
Les
Discussion New paint job. stewmeat95 Dock Talk 3 Jul 12, 2011 10:49 PM
Question How much does primer, paint job, decals, panel lines & teeth earn ya? DWA Slope 3 May 23, 2011 12:03 AM
Question Doing a paint job on polystyrene stubbyphilips Motorcycles 8 May 20, 2011 05:57 PM
