Old Jul 19, 2010, 06:15 AM
onlyifamppowered is offline
Find More Posts by onlyifamppowered
onlyifamppowered's Avatar
brisbane
Joined Jul 2005
idea's for a real slow indoor model?
HI
The group at indoor is always trying to achieve the slowest flight possible but the plane must fly on the wing, not hover or fly nose up using power to maintain height.
The plane must use commonly available light gear from the likes of hobbyking etc, not tiny micro stuff. We have been flying single skinned under-cambered wings and small brushless motors and weights of 150g ish.
We have a double basket ball hall to fly in so space is good, but always room to improve our designs. Any idea's?
onlyifamppowered is offline Find More Posts by onlyifamppowered
Old Jul 19, 2010, 09:07 AM
swervo is offline
Find More Posts by swervo
Perth Australia
Joined Feb 2010
hard to improve a design which i havent seen or have any details about but general rules apply , reduce weight and drag , increase lift .
swervo is offline Find More Posts by swervo
Old Jul 19, 2010, 11:01 AM
del is offline
del
Find More Posts by del
del
del's Avatar
north of Chicago
Joined Feb 2003
At the risk of seeming to blow my own horn, you might take a look at this thread:
http://www.rcgroups.com/forums/showt...ing+pennyplane
--del
del is offline Find More Posts by del
Old Jul 19, 2010, 11:07 AM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
somewhere i saw a VERY large built up indoor plane that weighed about 7 oz IIRC. it was supposed to fly at just about a walking speed. i'm thinking it was in the 70 inch size range.
derk is online now Find More Posts by derk
Old Jul 19, 2010, 12:37 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
The Kolibri design and variants have been around for a long time, probably at least 15 years. It is a CF rod and mylar covering design. Larger sized versions can use conventional mini-servos and equipment. Here's a link to a construction article here on RCGroups from way back.
http://www.rcgroups.com/forums/showthread.php?t=183298
The Kolibri type of design has been built in variations all the way from 4 or 5 grams weight up to several ounces, as well as with actuators and with servos, brushed and brushless. The Parkzone Vapor is actually just a commercial RTF version of a Kolibri (without the V-tail) very nicely done and using their micro servo brick.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jul 19, 2010, 05:41 PM
del is offline
del
del
del's Avatar
north of Chicago
Joined Feb 2003
Howdy Derk,
That might have been one of Henry Pasquet's, or my, duration models. In those days the rules for duration required that we haul around NiCad's, and the airborne r/c electronics were much heavier. To get models to fly that slow (reduced wing loading) they had to be _huge_..
They did fly slow. But were a pain to build and a bigger pain to transport. The biggest one I built had a wingspan of around 48 inches.
A fun thing to remember, but not something I'd care to do again given more modern equipment.
--del
Old Jul 19, 2010, 06:13 PM
del is offline
del
del
del's Avatar
north of Chicago
Joined Feb 2003
Originally Posted by onlyifamppowered View Post
HI
OK. I admit it...
I just got around to reading your post in detail, rather than just cranking out a quick response...
It's all about wing loading. To fly slow, you make that low. It's as simple as that. You need to tell us more about what sort of wing area your models have. But with even a standard Parkzone brick and drive it's not that difficult to get a model's all-up weight down to under 20 grams.
And, if you really want to fly slow, I'd suggest giving up on brushless motors, and buying idea-rip-off stuff from HobbyKing. Brushed motors are, in general, lighter; and you won't have to haul up an ESC and heavy LiPo's.
--del
Old Jul 19, 2010, 07:35 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Micro Power system w/ Gearbox GPS-6
Micro Power system w/ Gearbox GPS-7
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 19, 2010, 11:10 PM
Robster is offline
Find More Posts by Robster
RIP Sheba :(
Robster's Avatar
Brentwood, CA
Joined Nov 2002
As Del said it's all about wing loading. This has got to be one of the slowest RC indoor planes I've ever seen.. Just amazing! Well.. anyway food for thought. May want to reconsider using the small micro stuff.
5YOUKI (2 min 15 sec)
Robster is offline Find More Posts by Robster
Old Jul 20, 2010, 04:49 AM
brisbane
Joined Jul 2005
HI
Thanks to all for the idea's
I was thinking a little bigger then most of the idea's so far.
I know wing loading is the key and we do build fairly light but bigger and a little tougher to survive the mid-air's that always happen at indoor. Cyno and kicker is a pilots best friend at indoor !
I will attach a pic of the sort of model I have in mind. We use brushless motors of the CD Rom size, 2 S lipo of around 350mA and 5 five gram servo's
Just looking for other idea's to share and learn from
Old Jul 20, 2010, 07:14 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Can you tell us more about that one? Kit, scratch built or what? Any more pics of it?
potshot is offline Find More Posts by potshot
Old Jul 20, 2010, 02:20 PM
Boston, Mass
Joined May 2001
HI
That's very nice. No need to do a Kolibri type plane if you guys are already flying planes like that.
Here's a very low wing loading plane I'm slowly progressing on. More details can be found in this thread.
http://www.rcgroups.com/forums/showthread.php?t=1232909
Gordon
Old Jul 20, 2010, 06:26 PM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Can anyone find the pictures and/or videos of those huge jets and other planes that were stick and tissue but flew inside a tiny little gym? I think that they posted sometime last year in the fall or in the summer. I am almost positive that they are in this forum.
-PC49
PiperCub49 is offline Find More Posts by PiperCub49
Old Jul 20, 2010, 07:00 PM
Slider2732 is offline
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Is this the thread ?
http://www.rcgroups.com/forums/showthread.php?t=612610
Seems the vids have been removed though....might be on YouTube somewhere still.
Slider2732 is offline Find More Posts by Slider2732
Build Log Indoor stick and tissue cabin model for vapor brick The Don Scratchbuilt Indoor and Micro Models 33 Apr 27, 2010 08:35 AM
Discussion Benedini S/S for Foamies??? any idea... mapsyd Electric Warbirds 0 Mar 06, 2010 05:22 AM
Discussion Idea for light indoor type 3D -fun fly plane rcnutt Scratchbuilt Indoor and Micro Models 8 Jan 18, 2010 06:13 PM
Discussion Need suggestions for indoor slow flyer using my LPS B2-CS potshot Scratchbuilt Indoor and Micro Models 0 Nov 19, 2009 07:32 AM
Discussion Idea for a novel PSS model -YA-9 with sideforce control steveseibel Slope 6 Nov 12, 2009 08:22 AM
