Old Sep 02, 2008, 08:22 AM
Portchester Nr Portsmouth, Hampshire UK
Joined Nov 2006
3DX Motor
An older flying buddy wants to get a 3DX SAS on 3S22002P Lipo's, but is having trouble getting the Motor/ESC combo.
Loking around in UK I found this at BRC is there any reason for it not to fit (main shaft having to be reversed first NOTE he will be using about 1700/1800 headspeed and is to be used fory vERY mild training/sport flying this is to be sed with a HI-Model 60A PRO ESC at 40:-
HiModel Max-BL2820-07 (500W) 919Kv Brushless Outrunner Motor. brc087
NEW! HiModel Max-BL2820-07 919KV 500W (Plus) Brushless Outrunner Motor supplied with, Alloy Motor Mount & 3.5mm Gold Connectors
A very Powerful brushless outrunner motor capable of producing up to 500W (plus) making it ideal for larger electric models or IC conversions around .40 size.
BRC HOBBIES provide a free PROP DATA SHEET with each motor (unlike many sellers) to give you an idea of what prop size to use depending on your flight battery.
SPECS:
* Voltage: 3-4S Li-Poly
* RPM/V: 919kv
* Cont Current: 35A
* Max Current: 45A
* Dimensions: D38 x L46.9mm
* Shaft diameter: 5mm
* Weight: 145g
* Motor Shaft: 5mm
* Recommended prop (no gearbox): 11-12 inch
* Motor Mount: Included
* connectors: 3.5mm Included
* Recommended model weight: 800-2400g/5.1 lb
We were very impressed with the power of this motor when we tested it on 3S (11.1v) which also helps keep the cost of the project down.
A very powerful brushless motor capable of 500W (plus) powering models up to 2400g or 5.1 pounds!
Heritic
Heritic is offline Find More Posts by Heritic
Discussion 3dx motor mount,3 degrees? barebower 3D Flying 4 Mar 18, 2006 06:43 AM
Which 3DX motor? Scott MacAfee 3D Flying 1 Mar 08, 2004 12:14 AM
