Old Aug 02, 2001, 02:54 PM
Tantrums Rock!
CheeseWing's Avatar
Joined Jul 2001
110D vs. Supernova . . . for 50mah-1000mah NiMh cells
Is one more effective or better for smaller cells?
CheeseWing
CheeseWing is offline Find More Posts by CheeseWing
Old Aug 03, 2001, 08:23 AM
USA, NY, Jamestown
Joined Jun 2000
I have both but have not used the Supernova yet. The astroflight (only a year old) is not good for small cells as its display is not accurate at lower settings. I have an Astroflight micro wattmeter so I can better adjust. However the peak detector does not work this low. An example- I have a 300 mahr NiMH that I charge at 300mah. This rate will not display on the charger but does on the wattmeter. This is on slow charge mode which should work but does not.
Because of this this inaccuracy with the 110D I would vote for the Supernova.
JoeR is offline Find More Posts by JoeR
Old Aug 03, 2001, 06:01 PM
USA, NJ, Monroe Township
Joined Jul 2001
I don't own either of them but if I may, I would like to suggest an alternative. I have been using the Tekin BC 112A. It has an adjustable current from 0-4 or 5 Amp in 10ma increments. It peaks pretty well and can do nimh. I use it to charge my 300ma Nimh to my 3000ma packs. It can do 1 to 14 cells. Only down side is if you do more than 8 cells you need a 24V input as it does not have the circuitry to convert the input voltage any higher.
civh is offline Find More Posts by civh
For Sale MRC Superbrain 959 AC/DC charger for NiCad or NiMH cells Chuck Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 02, 2007 06:19 PM
Charger for AA individual NiMh cells ppowell Batteries and Chargers 5 Apr 17, 2004 02:16 PM
Max charge rates for High Performance NIMH Cells? MikeC Batteries and Chargers 1 Sep 28, 2003 08:01 PM
Sanyo AAAU 1000mah nimh cells $1 ea. Lance Aircraft - Electric - Airplanes (FS/W) 20 Jan 09, 2003 09:31 PM
Tell me how you like MAXX 1000mAh NiMH cells Andy W Batteries and Chargers 4 Nov 08, 2002 05:33 PM
