Old Dec 02, 2014, 01:59 AM
vil64's Avatar
Joined Nov 2012
Applying Litespan covering
Hi folks, I have a question.
I'm building a small dlg glider with an open structure wing. I know there are lots of choices how to cover it. I have found litespan covering in my workshop, which I believe would be perfect for this but I don't have balsaloc. It's a substance designed for this covering that works like glue. My question is, is there any other way I could apply this? Dope comes in mind but litespan is fully sealed material with no heat sensitive adhesive. Are there any alternatives?
vil64 is offline Find More Posts by vil64
Old Dec 02, 2014, 03:42 AM
Staffs, UK
Joined Nov 2003
Plain white wood glue....works almost like Balsaloc. If you spread it thinly on the frame and let it dry you can then use heat just like you do with Balsaloc.
Steve
slipstick is online now Find More Posts by slipstick
Old Dec 02, 2014, 04:47 AM
vil64's Avatar
Joined Nov 2012
Thanks Steve
Wow, I never thought of that. Is it really going to stick even after you let the pva glue dry? I never thought you can re-activate its stickiness by heat. I might try that on a piece of scrap. Good tip
Old Dec 02, 2014, 10:04 AM
Staffs, UK
Joined Nov 2003
I've used it quite few times with Litespan and other stuff and it's always held fine.
BTW this is one of the few cases where plain old PVA seems to work better than the fancy new aliphatic wood glues .
Steve
Old Dec 02, 2014, 12:49 PM
alevilla's Avatar
NOVARA - ITALY
Joined Dec 2003
I definitely understood that Balsaloc has a base of white glue (here in Italy is tipically known with commercial name of "Vinavil").
I used white glue diluted with some water.
Water hepls white glue to better soak the wood. I recently built a Slingsby Skylark by WestWings covering it with litespan and white glue with water. Even if you see the balsaloc tin, inside it there was white glue + water.
https://plus.google.com/photos/10791...15237680127153
Bye
Alex
alevilla is offline Find More Posts by alevilla
Old Dec 02, 2014, 10:44 PM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Or you can use a foam brush and 'paint' the back of the litespan and then apply it like any other covering film.
I also use white glue. I like plain Elmers. I do not recommend the cheaper no name brands and stay away fron the kid or school safe versions (they are 'safe' to eat ).
charlie
portablevcb is offline Find More Posts by portablevcb
Old Dec 03, 2014, 03:45 AM
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
I use Balsaloc and would think that it isn't made from ordinary PVA because it is quite difficult to remove from the sole of your covering iron and also from your fingers (PVA simply peels off). It dries as a very thin, transparant, flexible plastic coating.
A little messy but it works really well though. I've never had covering come loose when using Balsaloc although I haven't tried PVA for the same job.
DeeBee1 is online now Find More Posts by DeeBee1
Old Dec 03, 2014, 04:01 PM
Canada, ON, Newmarket
Joined Jul 2013
Here are more options/discussion of replacements for Balsaloc/Balsarite:
http://www.rcgroups.com/forums/showt...s#post27645194
I found the Modge Podge, readily available at craft stores, works well.
My caution with thinned pva is the water distorting balsa sheeting; probably on sticks would be fine.
good luck
Michael
2michaely is offline Find More Posts by 2michaely
Old Dec 04, 2014, 10:11 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
I would not thin the white glue if applying it to the frame work.
I also second Modge Podge as a good alternative to white glue. IIRC it is also a little more resistant to moisture.
Old Dec 05, 2014, 06:12 PM
Paul's Avatar
United States, CT, Enfield
Joined Nov 2000
Wow, I always used Elmers white glue, diluted 50/50 with water, to apply Japanese tissue to free flight planes.
I wonder if you could paint the frame of a FF model with diluted white glue, let it dry, and iron on the Japanese tissue with a trim iron or adjustable heat soldering iron?
Paul is offline Find More Posts by Paul
Discussion Apply covering film to depron ..? AlphaWhisky Foamies (Scratchbuilt) 7 Sep 18, 2014 02:50 AM
Discussion Can I apply solite covering over plastic? luv2fly Painting and Finishing Tips 1 Jul 05, 2014 10:29 PM
Sold << Price Reduced >> Litespan Ultra-Light Iron-On Covering modestmagi Aircraft - General - Miscellaneous (FS/W) 3 Feb 24, 2014 11:45 AM
For Sale Litespan Ultra-Light Iron-On Covering modestmagi Aircraft - General - Miscellaneous (FS/W) 0 Dec 15, 2013 02:31 PM
For Sale Litespan Ultra-Light Iron-On Covering modestmagi Aircraft - General - Miscellaneous (FS/W) 6 Nov 23, 2013 04:40 PM
