Old Apr 30, 2004, 01:14 PM
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Rave
4.3V/cell Li-Ion Maximum
Dave H.
Check out the website http://shdesigns.org/lion-opt.html about charging
Li-Ion cells. It is found on modifying for different size cells.
hall woo is offline Find More Posts by hall woo
Old Apr 30, 2004, 01:25 PM
Walled Lake, MI, USA
Joined Feb 2000
Yes, it says that 4.3V is the "maximum allowed" voltage per cell. So if you charge a series pack to an average of 4.3V per cell, and if the cells in the pack are slightly out of balance, that means that some of the cells will exceed the absolute maximum of 4.3V. There is also the problem of variation in meters that could lead, for instance, to something measuring 4.3V on a meter when it is actually 4.35V.
Leaving a margin for cell imbalance and meter error is why every single Li-ion cell manufacturer in the world recommends a maximum charger setting of 4.2V per cell. It is dangerous and irresponsible to suggest otherwise. Given the serious risk of explosion and fire with metal-jacketed Li-ion cells, it is simply not worth the potential of personal injury or property damage to exceed the maximum charger setting recommended by all Li-ion cell manufacturers.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Apr 30, 2004, 03:56 PM
Peter Khor's Avatar
Mostly in Norman, OK
Joined May 2002
Photo from sometime back ... iirc the charger was a voltage-limited type (LM317 based I think) setup, pack was left on the charger for a couple of hours before it blew. Battery and Charger was mfg'd for 1/18 scale R/C cars by Novak, they had to issue a recall notice and paid for several damages, so I was told (this fire damaged the car and onboard electronics, and burnt a portion of carpeting, fortunately owner was home at the time of the incident - Novak paid for damages). Novak stop carrying the Li-Ion options and hasn't even bothered to try again.
Peter Khor is offline Find More Posts by Peter Khor
WTB: 3 cell Li-ion (Lithium) Charger Nik-rc Aircraft - Electric - Airplanes (FS/W) 7 Nov 10, 2003 07:09 PM
I want to build a couple 3 cell li-ion packs scruz Batteries and Chargers 1 Mar 28, 2003 09:56 AM
Single Cell Li-Ion testing looks good Gene Bond Scratchbuilt Indoor and Micro Models 3 Apr 25, 2002 07:45 AM
building 3 cell li-ion packs, precautions? foss1997 Power Systems 2 Apr 18, 2002 09:50 PM
Yippee! woohoo I burned through 4 1200 mAh Li-ion packs today. The Other Dave Parkflyers 0 Jan 27, 2002 06:38 PM
