Old Jan 20, 2015, 01:46 PM
London, ON, Canada
Joined Nov 2010
Originally Posted by Nathaimu View Post
Hi everyone.
I am building a pretty big hexacopter that carries a GH4 camera on an Align gimbal. It is a custom build, so the pieces don't always fit together, but so far everything found its place, and the hexa flies pretty great.
Just to be clear, here is a basic description of what I am using at this point :
- Wookong M
- Graupner MZ18 radio and GR24 Rx
- 16000MAh 6S battery
- 3S battery as secondary
Pretty simple...
Still left to add to the system :
- Lightbridge
- Gimbal and camera
As I said, in this configuration, and with no gimbal or Lightbridge, the Hexa flies perfect, but my problems start when I use the LB Air Sytem as a receiver. When I do that, the hexa "stutters", or coughs if you prefer. I would not dare to fly it.
So just to be clear, when I use the lightbridge (and UNplug the GR24 Rx), everything responds fine, everything is calibrated in LB and Wookong, motors start as they should, but while the motors are working, I can see and hear small "jumps". It is as if the system stops for a millisecond and starts again, like little coughs, or some kind of irregular jitter.
Has anyone experienced something similar ?
quick question on your radio setup before I answer my guess as to what's happening. For your throttle, is it centered with spring tension to re-center similar to other stick?
padair is offline Find More Posts by padair
Old Jan 21, 2015, 07:12 PM
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
Originally Posted by AlchemistAerials View Post
Not sure if I can post this here or if it was already addressed. I shoot mostly fast action aerials, car chases, car commercials, speed boats eyc, I was holding out on buying a lightbridge because of latency issues. I only fly about 1000ft away most of the time.
Have any of the new updates improved latency issues? Or have any of you been able to shoot fast action scenes without problem?
Thanks!!!
Latency depends a lot on the device you are streaming the video into. An iOS device with an A7 or better processor has been demonstrated to have 220-250ms latency. Connect it to an HDMI device and it is lower. The latency for me is acceptable. There was one version of the beta firmware that had about 1000ms delay and that was not good for anything. Fortunately that has been fixed almost a year ago while we were still in Beta.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: Landing Gear Reset S800
Old Jan 22, 2015, 08:12 AM
Discovery
ulkar's Avatar
Joined Apr 2012
I made a test yesterday with a 280ms latency out of a GH4 zenmuse into a liliput hdmi screen
ulkar is offline Find More Posts by ulkar
Old Jan 22, 2015, 11:25 AM
DJI SUPPORT / TESTING
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
That's actually very good for a digital system. Each component in the chain will add to this, including the hdmi monitor.
blade strike is offline Find More Posts by blade strike
Site Sponsor
Latest blog entry: New ** 6s1p Dinogy 22,000mAh**
Old Jan 23, 2015, 07:41 AM
Discovery
ulkar's Avatar
Joined Apr 2012
I know, but for fast framing that's out of the question, how can paralinx provide a 1ms latency digital signal?
Old Jan 23, 2015, 09:50 AM
Joined Jan 2006
I doubt it's 1ms and if that is just for the transmission not any other components in the chain. I do know they have very low latency but very low range as well. There are positives and negatives with every system.
Site Sponsor
Old Jan 23, 2015, 10:01 AM
Discovery
ulkar's Avatar
Joined Apr 2012
What I was wondering is what induces latency in the transmission, as the output from the GH4 should be 0 latency, when it goes through analog it's still taking the signal from that port and then converted to analog, while there's no visible lag in the analog transmission
Don't get me wrong I love the lightbridge we're using it for several setups, just we can't when the framer has to be lighning fast (race cars for example)
Old Jan 23, 2015, 10:23 AM
Joined Jan 2006
The output from the gh4 has latency as well. Like I said no digital system has 0 latency. The Gh4 still has latency through it's output, I would guess somewhere in the 20-40ms range. Then add the conversion board, probably another 10-20ms. Still very little and would bet a human wouldn't even notice it unless looking for it. But as you can see each digital component creates latency in the chain, even your LCD will add some.
Site Sponsor
Old Jan 26, 2015, 02:08 PM
Happy FPV flyer
Kilrah's Avatar
United Arab Emirates, Dubai
Joined Sep 2006
1ms is the latency ADDED by the Paralinx "component" to the whole transmission chain. They achieve it by keeping the video uncompressed, which means high bandwidth and is why range is much shorter.
The added latency for the Lightbridge is about 100ms, so by using a Paralinx unit you'd only shave that much off the total latency. Most cameras with an HDMI output have more than 100ms latency of their own, some up to 200ms.
Kilrah is online now Find More Posts by Kilrah
Old Feb 02, 2015, 05:43 PM
DJI Support
Joined Feb 2010
Has anyone gone from LB to SDI and direct to broadcast. If so what equipment did you use and if you had issues what did you do to solve them?
Site Sponsor
Old Feb 03, 2015, 03:45 AM
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
Yes, I recently flew 3 drones into the Sydney NYE fireworks for ABCTV Australia.
They converted to SDI with no issue. We used a Blackmagic HDMI to SDI converter like this:
https://www.blackmagicdesign.com/au/...pecs/W-CONM-20
They then went to broadcast.
The issues were:
1) LB could not stream full hd 1080i as there was too much movement on screen and the data rate was too high resulting in broken pictures, even with twin helical antennas on the ground and CLA and SPA in the air. (and noise floor was high with a million people below all with mobile phones and WiFi switched on)
2) Both smooth and real time modes 720P worked better, with smooth being the best.
3) They had issues up converting to 1080P from 720P out of light bridge, so the only work around was to down convert to 576 which allowed a native upscale to 1080 in their application software. No idea why they could not do 720 to 1080.
Psionic001 is offline Find More Posts by Psionic001
Old Yesterday, 11:13 AM
Toronto Canada
The LB still wont work with an ipad air correct? I see that apple let dj use the pilot app on IOS.
lilphil26 is offline Find More Posts by lilphil26
Old Yesterday, 09:11 PM
DJI Support
Joined Feb 2010
I use an iPad Mini with Retina display. The Air is used by many.
Site Sponsor
Old Yesterday, 10:28 PM
Toronto Canada
Oh ok cool. I thought Apple wouldn't let dji run video through the Lightning connector
Old Yesterday, 11:11 PM
Happy FPV flyer
Kilrah's Avatar
Joined Sep 2006
The app is not published anywhere anymore though.
New Product DJI Lightbridge HD Video + Digital Link mkmkmk13 FPV Talk 29 Jun 28, 2014 04:08 AM
For Sale Mobius Full HD 1080P FPV / Surveillance camera with TV/Video out cables kazmandy FPV Equipment (FS/W) 0 Oct 28, 2013 11:07 AM
For Sale The Smallest Mini DV Camera 5.0MP HD Digital Video Recorder ahub Aircraft - General - Miscellaneous (FS/W) 0 Oct 11, 2013 03:14 PM
Sold ($225) Panasonic HDC-HS250 120GB Full HD Cam Digital Camcorder - 1080p Whoaty55 Non R/C Items (FS/W) 1 Oct 09, 2013 09:16 AM
