Old Dec 23, 2012, 10:22 AM
United States, CA, Mission Viejo
Joined Jan 2005
Charger Recomendations
I know there is an entire thread on batteries and chargers but want to ask here to see what you guys would use.
I am using 3 and 4 cell 3000 mAh batteries in series and parallel to make up a 12,000 mAh 16 cell pack.
I don't have a charging setup and look to get myself one for Christmas.
Any suggestions for this?
Thanks and happy holidays
Rick
Air Head is offline Find More Posts by Air Head
Old Dec 23, 2012, 12:22 PM
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
FMA Powerlab 8
I use the Powerlab 8 and charge 4ea 6 cell batteries simultaneously at up to 10 amps each. That is 40 amps charge. To do that requires 24 volts in at around 50 amps. Running off 12v would limit the charge to 20 amps. It will do 8s but I am not configured that way. You would need to configure your packs to 8s and arrange your balance leads accordingly. When charging in parallel, the batteries must be at a similar charge condition at the start and obviously the same cell count.
I fly 12s with 4ea, 6 cell packs in series/parallel and charge all four real quick!
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Dec 23, 2012, 02:14 PM
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Power Lab 8 it is the safest most powerful charger available.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Dec 23, 2012, 02:35 PM
Not Funny......
Mike Warren's Avatar
United States, CO, Redstone
Joined Dec 2010
This one is also very good and is 12v/24v as well:
Hyperion EOS 0720i Super DUO3 7S Dual Port Charger
I too would suggest setting up as two 8s packs; ......and good luck sorting out the balance leads if you go with what you described in your first post
Mike Warren is offline Find More Posts by Mike Warren
Old Dec 23, 2012, 03:02 PM
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
I'll offer what I'm using, which is at the opposite end of the price $pectrum. It's all from HobbyKing, so ... well ... you know - caveat emptor and all.
I use it to charge (4) 6S 2200 packs in parallel. I can't fault it - works exactly as specified!
But I'll repeat previous warnings from upthread: balance boards only work with the same cell counts in parallel.
tn
QTY
Stk
Product description
Price
OK
T-30PS-110 - HobbyKing 540w 100~120v Power Supply (13..
$61.58
OK
T400W-V2 - TURNIGY MEGA 400W V2 Lithium Polymer Bat..
$66.79
OK
PCB004 - Hobbyking Parallel charging Board for 6 ..
$8.99
OK
BOX-183g - Extra Size Cardboard Box and Packing 183..
$0.00
TOTAL: $137.36
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Dec 23, 2012, 03:22 PM
Joined Jan 2005
Turnigy MEGA 400Wx2 Battery Charger/Discharger (800W)
I just saw this one while looking at the 400 watt charger at Hobby King.
Anyone use this one?
Old Dec 27, 2012, 02:31 PM
Joined Jan 2005
How about this 12 volt batteries
What if I get a couple 12 volt batteries and 12 volt chargers and use these for the power supply? This way I can take it to the field and get a couple chargers that are not tied to the 110 volt circuit,
Old Dec 31, 2012, 06:40 PM
DForbes's Avatar
Michigan
Joined Jun 2005
Powerlab
Hey Tom, I am also looking at the Powerlab 8 and use mostly 6cell batteries. How are you able to pull 40 amps? What size power supply are you running and are you using a single wall plug? Wouldn't a single wall plug be limited to 20-25 amp?
Dennis
DForbes is offline Find More Posts by DForbes
Old Dec 31, 2012, 08:42 PM
St. Mary, Maryland, United States
Joined Dec 1996
Dennis
wall plugs in the US are generally 15 amps, some are 20. Of course the is 120 volts. 1,800 or so watts, more than 20 amps when converted to 12 volts!
Chris True is offline Find More Posts by Chris True
Old Jan 01, 2013, 12:33 AM
Joined Sep 2006
cellpro powerlab
Dennis,
I use this set up in the car and is described here on post 116:
http://www.rcgroups.com/forums/showt...1600060&page=8
Help! First charger, any recomendations?? flyin C Batteries and Chargers 17 Oct 09, 2007 10:49 PM
recomendation on chargers src053 Batteries and Chargers 19 Jul 20, 2005 05:21 AM
What charger do you recomend... MarkChinery Batteries and Chargers 9 Aug 11, 2004 04:32 PM
Charger recomendations and tecniques! av8rOC Batteries and Chargers 7 Dec 20, 2002 01:31 AM
