Old Oct 26, 2012, 07:11 AM
Joined Oct 2012
New Product
T700 Hexacopter launching now
[attach]5258582[/attach
Description:
Description:
Description:
Lijuping is offline Find More Posts by Lijuping
Old Oct 26, 2012, 07:19 AM
Joined Oct 2012
Aircraft dimension   700 700 320 mm
Maximum expandable size 1010 1010 320 mm
Folded size D160 560 mm
Motor to motor Diagonal distance between two motor centers 700mm
Propeller 1260 Engineering plastic/or 3K carbon fiber 12inch
Battery LiPo 4S 10000mAh 20C standard1P
Aircraft weight(kit only) Without battery, receiver, applicable payload 1610gram
Take-off weight 4S 10000mAh 1P battery、receiver 2390gram
Recommended payload DV/Card-type camera ≤700 gram
Maximum pull 1P standard battery 7000 gram
maximum payload 1P standard battery ≤1200 gram
Maximum take-off weight 1P standard battery 3000 gram
Flight distance Visual area -
Flight time1 3S 4250mAh 1P battery.receiver RESERVE
Flight time2 4S 10000mAh 1P battery.receiver 25~30 mins
Flight time3 5S 10000mAh 1P battery.receiver GPS
Wind resistance ≤5,4 class wind, can cruise normally Class
Old Oct 26, 2012, 07:52 AM
James not bond
jy0933's Avatar
Joined May 2012
weight of frame?
jy0933 is offline Find More Posts by jy0933
Old Oct 26, 2012, 08:06 AM
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
I personally think they should increase the tubing diameter for the arms. 12mm is a little on the small side. I would preferably like to see it atleast 16mm in diameter.
malcr001 is offline Find More Posts by malcr001
Joined Jan 2010
PTZ-A 230g
PTZ-C 360g
490905002 is offline Find More Posts by 490905002
Old Oct 26, 2012, 08:11 AM
Joined Jan 2010
Although it is 12mm, but the material is 3K carbon fiber woven tube.And 20mm aluminum tubes, the intensity is much higher.
Old Oct 26, 2012, 08:17 AM
Joined Oct 2012
please click here learn more information about our PTZ:http://www.lotusrc.net/product1.asp?...ct1.asp?id=317
Old Oct 26, 2012, 08:19 AM
Joined Oct 2012
the weight of kit is 1600g Without battery, receiver, applicable payload
Old Oct 26, 2012, 08:20 AM
Joined Oct 2012
Originally Posted by jy0933 View Post
weight of frame?
malcr001's Avatar
Joined Nov 2007
So your saying 12mm CF tubing is more crash resistent than 16mm CF tubing?
Does the multicopter use CF tubing and aluminum tubes or is either one or the other?
What size props does this frame use?
Old Oct 26, 2012, 08:25 AM
Joined Jan 2010
flight picture
Description:
Description:
Description:
Old Oct 26, 2012, 08:26 AM
Joined Oct 2012
it is sure 12mm 3K carbon fiber tube is more stronger than 20mm aluminum tube
Old Oct 26, 2012, 08:27 AM
Joined Jan 2010
12" Engineering plastics or 3K carbon fiber material.
Old Oct 26, 2012, 08:28 AM
Joined Oct 2012
we will use 12inch propellers
Old Oct 26, 2012, 03:07 PM
Joined Jun 2012
Stakka Bo Here we go again from 1993 (3 min 58 sec)
2 questions
can we have pictures of the flight controller and esc's please?
and
can you confirm this is NOT the same sort of thing as the t580?
ie if ONE ESC dies does this now mean we have to buy THREE esc's to replace the failed one?
neobot is offline Find More Posts by neobot
Reply With Quote  (Disabled)
Discussion T600 stretched to a T700 cap231ex Scale Helicopters 79 Dec 08, 2012 08:58 PM
Discussion Hexacopter RQCX-3 "Raven" now flying... Lucidity47 Multirotor Talk 0 Jan 05, 2012 10:45 PM
For Sale Now It's ready to Run!! Used Clutch Winch for Launching Sailplanes rogerflies Aircraft - Sailplanes (FS/W) 0 Sep 29, 2006 06:47 PM
