Old Sep 21, 2014, 06:07 PM
Joined Dec 2009
Help!
Old Seamaster question
I have an old Seamaster (I think a Ken Willard design) that I got from a friend who put it into a tree. I have fixed all the damage and now in the process of putting it back together and getting it covered. My question is, what should be the incidence be between the wing and tail? Should both be zero? The way it sits right now or the way it was originally built, if the wing is at +2 1/2 degrees the tail is close to zero. Seeing that it is still in pieces I can fix the incidence now before gluing the tail back on. Most all of my other planes the wing and tail are at zero. I did set up a Cub on floats and I know that there is about a +2 degrees between the wing and the floats. My guess would be that the wing & tail should be zero just like my other planes, but not sure.
Thanks, Jeff
jstern429 is offline Find More Posts by jstern429
Old Sep 22, 2014, 09:18 AM
Wormboy's Avatar
Australia, WA, Madeley
Joined Jul 2011
Heya Jeff,
I don't have experience with that model directly but may offer a little advice.
Most seaplane models I've come across seem to have a little positive on the wing, 2.5 deg sounds about right.
It seems to help lift off the water easier without having to rotate all the way through to the AOA needed for take off. The converse is that it does have a sweet spot on the throttle, above which it will balloon when in flight unless you add a bit of down elevator.
I'd be inclined to leave it as is.
Wormboy is online now Find More Posts by Wormboy
Old Sep 22, 2014, 10:35 AM
Joined Aug 2004
Link to the original plans here:
http://www.outerzone.co.uk/plan_details.asp?ID=5899
pookielips1954 is offline Find More Posts by pookielips1954
Old Sep 22, 2014, 10:44 AM
Joined Dec 2009
Great, thanks for the info. Jeff
Old Sep 22, 2014, 10:51 AM
Joined Dec 2009
Any idea who made this kit? From the plans that pookielips1954 gave a link to it doesn't seem to be that plane. It was built not an ARF, has a 60" wing span and had a 60 size glow motor in it when my friend got it. He converted it to electric and I plan on keeping it that way.
Thanks, Jeff
Old Sep 22, 2014, 03:47 PM
Joined Aug 2011
The original kit yours was built from was made by Ace RC from Higginsville, MO.
The ARF was made (very well) by Thunder Tiger, now sadly out of production.
There is now a new lighter built clone called a Neptune, made by a different outfit, that looks very similar.
Mark 2 is offline Find More Posts by Mark 2
For Sale Ace Seamaster 40 kit monroec Aircraft - Fuel - Airplanes (FS/W) 1 Oct 10, 2014 06:54 PM
Discussion Old Astro 10 with gear box questions. maxnew40 Power Systems 6 Dec 09, 2013 09:47 AM
Discussion Martin Seamaster Trumf Pusher Prop Jet Models 0 Oct 23, 2013 03:03 PM
Discussion Which one Lanier Mariner 40 or Ace Seamaster or Thunder Tiger Seamaster jdcook54 Waterplanes 10 Dec 02, 2007 07:04 PM
Discussion Seamaster ARF question. air mail rcg Fuel Plane Talk 0 Sep 03, 2007 12:46 PM
