Old Mar 07, 2014, 06:56 AM
Joined Dec 2013
Transmitter distance
I thought I read once that my transmitter would work up to 3000ft.? Is that realistic? Even 2000ft seems a long way. That's 666 yds. Guess I should have asked a while back because I've only been going about 300-400.
Lovegolf is offline Find More Posts by Lovegolf
Old Mar 07, 2014, 07:17 AM
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Do a range test and remove all doubt.
Granted is online now Find More Posts by Granted
Old Mar 07, 2014, 09:23 AM
Joined Jan 2011
The Spektrum PARK FLYER receivers/transmitter combos have been tested to work up to 3.7 miles line of sight.
bbells is offline Find More Posts by bbells
Old Mar 07, 2014, 10:13 AM
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
Unless you're flying like a 1/2-scale or 5M w/s model, you are probably good for range beyond being able to tell which way up it is
I have a 1.5M w/s model that was so far away I was having trouble telling which way it was headed ! Not even a twitch of a problem
RWData is offline Find More Posts by RWData
Old Mar 07, 2014, 04:59 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
As noted above, for normal RC flying you don't need to be concerned at all about the range of the radio. It's always the range of your eyesight that is the limiting factor.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Discussion What's the best long distance A/V RCA transmitter & receiver? swbluto FPV Talk 9 Aug 31, 2013 10:29 PM
Discussion Range "distance" I can expect out of a transmitter and receiver for a boat? spiderjason Dock Talk 14 Dec 31, 2012 08:55 PM
Discussion Dynam transmitter/receiver distance? tschiska Radios 1 Nov 02, 2012 12:15 AM
Help! Transmitter malfunction after certain distances? WeeksFlyer Beginner Training Area (Aircraft-Electric) 17 Jun 22, 2010 09:12 AM
Discussion 900mhz - Distance or quality difference between 1w vs 500mw transmitters EdHall FPV Talk 9 Sep 18, 2009 04:13 PM
