Old Sep 11, 2013, 12:37 PM
Joined Nov 2012
For the thrust i need more power so i was thinking to use a 128mm duct for the lift fan and a 120mm fan for the 3 bearing swizel module. my swizel duct is now 90mm so I have to make a new one and I need to use stronger servo's. do you guys have any ideas to make this project a success? I have the recipe to make a nice hover and transition to horizontal flight, now I need the power!!!
Joel_Vlashof is online now Find More Posts by Joel_Vlashof
Old Sep 11, 2013, 12:38 PM
Joined Nov 2012
Rc f35 vtol (1 min 27 sec)
Old Sep 11, 2013, 12:39 PM
Joined Nov 2012
This video i was testing it with strong wind.
Old Sep 11, 2013, 12:43 PM
As I mentioned, try to make the duct optimized for hover rather than for forward flight. Make a bent duct and cut it into the three sections needed to turn into a straight duct. when it is straight it will be slightly S shaped, but it won't have any "kinks" in any configuration, and it is more important to have the most possible thrust in vertical flight than in conventional flight.
Brandano is offline Find More Posts by Brandano
Old Sep 11, 2013, 03:19 PM
Finland, HKI
Joined Apr 2013
Originally Posted by Joel_Vlashof View Post
This one is 2,25 meters long
What is the weight of this aircraft? My 2,2 m fighter weight some 5 kg (inc. motors and batteries).
MrJan is offline Find More Posts by MrJan
Old Sep 13, 2013, 12:31 AM
United States, VA, Virginia Beach
Joined Apr 2013
Is this one on the market or did u build it urself?
louisjunior is offline Find More Posts by louisjunior
Old Sep 13, 2013, 12:38 AM
Joined Apr 2013
I second the advice. A stable hover flight is much more accomplishment than a conventional flight going 100mph. At least u're doing it right but working on vertical takeoff first and later on moving to conventional flights when everybody else tries to do it the other way.
Old Sep 14, 2013, 02:19 AM
Joined Nov 2012
This one is on the market, there are 2 company´s. Jetlegend And Fly Eagle Jet.
Old Sep 14, 2013, 02:23 AM
Joined Nov 2012
Emty Weight of this plane is 8 kilo´s i don´t know the total weigt jet. but i thinks about 12 kg. this is a big project
Old Sep 14, 2013, 02:36 AM
Joined Nov 2012
Thanks This was my firt goal to make a nice hover first. I calculated the CG of this mockup. but fist i going to make false wings and body to see what happend when i do a hover. and what it does in wind, perhaps my gain is to high or to low
Now i am upgrading the 65mm fan to an 70 mm fan,for the rear nozzle to try a faster forward flight whitout the wings. my goal is 45km/h horizontal. this is the speed when my wings are gaining lift. I will try to give you guys once a week an update about this project
Old Sep 14, 2013, 10:33 AM
Finland, HKI
Joined Apr 2013
You better get 16kg thrust. How you think you get it?
Old Sep 14, 2013, 10:45 AM
Finland, HKI
Joined Apr 2013
If you get it air born there is about million different reason why it land not so wanted way. And if one of them occur, your beautiful aircraft will destroy. Can you reach 100% succeed?
Old Sep 15, 2013, 03:15 AM
Joined Nov 2012
thrust
Perhaps these ductedfans from Dr.Mad Thrust. 2 120mm and 2 70mm. Iam still looking and searching for the right motors
Old Sep 15, 2013, 03:17 AM
Joined Nov 2012
[QUOTE=Joel_Vlashof;26114876]Perhaps these ductedfans from Dr.Mad Thrust. 2 120mm and 2 70mm. Iam still looking and searching for the right motors[/QUOT
total thrust off 19,90kg....
Old Sep 15, 2013, 03:21 AM
Joined Nov 2012
molded f35 rc groups.
The guy who build this was far but i did not saw him make a hover
