Old Jan 26, 2009, 11:42 PM
San Diego
Joined Dec 2008
Spektrum AR6100 receiver
This is really a dumb question. But allow this newbie to ask. I'm selecting electronics for my first build of a EXI 450ma. I'm considering (unless you think these are not suitable for the EXI 450ma) 3 HiTec 65mg servos, Futuba GY401 gyro and Futuba 9650 tail servo and a Spektrum AR6100 Microlite Receiver (I have the Spektrum DX7 Tx). Will these electronics pieces have standard plugs that will connect to the Spektrum AR6100 Microlite Receiver?
photogeye is offline Find More Posts by photogeye
Old Jan 26, 2009, 11:45 PM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Yes. Except that you may need to trim the tabs off the Futaba connectors to allow them to fit the receiver. Not a problem, just use a little care.
I can't speak about the EXI but this is pretty much the setup I use on my TrexSE v2 (except I use 9257 tail servo). The HS65MG are very good servos.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jan 26, 2009, 11:51 PM
San Diego
Joined Dec 2008
Thanks Daedalus66. btw way is the 9257 tail servo better?
Old Jan 27, 2009, 12:55 PM
RC4Life not just 4 xmas
p4ddy's Avatar
southampton uk
Joined Jun 2006
I use both 9650 & 9257. In flight i feel no difference, the 9257 does seem to be a lot smoother though. As for the tabs, i just filed them (with a sandpaper type nail file) until they fit, this i had to do on the AR6100 & 7000
p4ddy is offline Find More Posts by p4ddy
Old Jan 27, 2009, 03:26 PM
dude_109's Avatar
Houston, TX
I had to cut the Futaba tab off my GY401 plug since I was using AR7000. If you use AR6100e you won't have to cut/file the gyro plug.
dude_109 is offline Find More Posts by dude_109
Old Jan 27, 2009, 03:44 PM
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
the ar6100e has the plugs in the back and their open where as the regular ar6100 plugs in on the top and its inclosed
bad400 is offline Find More Posts by bad400
Old Jan 27, 2009, 10:59 PM
San Diego
Joined Dec 2008
Is the Spektrum AR6100e.... e for "end plug"? btw way thanks again for the advice and suggestions.
Old Jan 27, 2009, 11:51 PM
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Yes, end plug... there's a little tab on the Futaba servo plugs, and on the one with the angle plugs, the Futaba connectors can be hard to get in, but they will go in. On my Trex 450, I had to use the angle plug receiver because of the way things 'worked out', but I re-wired the Futaba gyro plug so it wasn't an issue.
In the photos it shows the "angle" receiver, and I've wired the BEC into the gyro signal wire.
jasmine2501 is offline Find More Posts by jasmine2501
Old Jan 28, 2009, 01:44 AM
San Diego
Joined Dec 2008
Jasmine those photos are just what I needed to see. Not having a Trex 450 SE v2 yet, would you recommend the AR6100 angled or end receiver?
Old Jan 28, 2009, 01:59 AM
Rocket Programmer
Joined Jul 2007
If you want to mount it where I have mine then you'll need the angle one, but a lot of people like to put the gyro there and the receiver on the bottom deck. I personally don't like that method because I can't see the lights on the gyro that way, but if you put the receiver on the bottom deck, you can use the end pins. I happened to have some extras here, so it wasn't a big deal to me to switch, but if you want one that will work in both spots, get the angled one, which works fine on the bottom deck too.
Old Jan 28, 2009, 02:28 AM
p4ddy's Avatar
southampton uk
Joined Jun 2006
Oh yea, i remember i have the e so it was just the 7000
Sold SPektrum-AR6100 Receiver mike p de l Aircraft - General - Radio Equipment (FS/W) 5 Jan 13, 2008 02:45 PM
Question Spektrum AR6100 Receiver Price tarm Radios 16 Dec 15, 2007 03:20 PM
Sold Spektrum AR6100 Receiver...LIKE NEW...WORKS FLAWLESSLY! bighank13 Aircraft - General - Radio Equipment (FS/W) 1 Dec 04, 2007 09:52 AM
For Sale spektrum ar6100 receiver topforce Aircraft - General - Radio Equipment (FS/W) 0 Aug 05, 2007 10:33 PM
Found Spektrum AR6100 Receiver kel.jackson Aircraft - General - Radio Equipment (FS/W) 4 Aug 01, 2007 08:29 AM
