Old Jun 03, 2005, 12:27 PM
burr ridge illinois
Joined Oct 2003
110 Volt Lipo charger--HELP!
I want to travel with a small plane and need a small Lipo charger that can run on 110 Volts instead of the usual 12 Volts. It would be to charge 3s 860-1320 packs.
I'm hoping for something like a wall charger in terms of size (small, like the chargers we get for our radios).
It'd also be nice if I could adjust the current, with a knob or switch (nothing fancy).
I didn't come up with anything good searching.
Any suggestions?
Thanks!
Eric
echassin is offline Find More Posts by echassin
Old Jun 03, 2005, 12:37 PM
mexico's Avatar
NJ
Joined Aug 2003
I have never seen anything like that. I assume it is because it would not be able to provide the regulated power needed. If you are driving you could simply run your charger off your car's battery. If you are flying do you plan on renting a car? Otherwise you will probably have to bring your power supply.
mexico is offline Find More Posts by mexico
Old Jun 03, 2005, 02:24 PM
burr ridge illinois
Joined Oct 2003
Lugging the power supply is exactly what I was hoping to avoid.
I'm surprised there aren't more 110V-input chargers. I'll bet a significant amount of Lipo charging occurs at home, where the power supply is just a extra thing to worry about.
I made a 22"X14"X9" coroplast box (the limit for carry-on) that holds radio, lipos, charger, and plane, but will not hold my power supply. I could carry it in the clothing suitcase, but the idea was to have a completely self-contained "kit".
Anybody?
Old Jun 03, 2005, 02:31 PM
Sterling Heights, Michigan, United States
Joined Nov 2003
If it's a small plane, you can use a wall transformer that can put out 1.5 amps. and use one of the lm317 li-po circuits found in one of the DIY lipo threads. This would give you about a 1-2 hour charge rate. I've been using the circuit and find it quite reliable, even made a pcb board for it.
http://www.rcgroups.com/forums/showt...26#post2822523
Kin
http://www.embeddedtronics.com/
kfong is offline Find More Posts by kfong
Old Jun 03, 2005, 03:23 PM
ebill3's Avatar
United States, WA, Puyallup
kfong's idea is good. But if you are not into DIY, how about a small (4.5" x 2.5" x 1.5") switching PS from Mouser. 12 V and 30 watts ought to take care of the batteries you are carrying.
Mouser Electronics
Bill
ebill3 is offline Find More Posts by ebill3
Old Jun 03, 2005, 05:01 PM
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
I believe balsa products has wall-wart lipo chargers available. But if you only want a power supply, anyone of the online surplus electronics stores has small 12V switching power supplies that are very slim and lightweight.
http://www.mpja.com/productview.asp?product=15548+PS
DavidB. is offline Find More Posts by DavidB.
Old Jun 03, 2005, 05:12 PM
hybris's Avatar
Houston, TX
Joined May 2003
This will work for your 1000mAh and above 3s lipos. You should be able for find one that charges 800mA also.
http://www.balsapr.com/common/keywor...21558162005765
hybris is offline Find More Posts by hybris
Old Jun 03, 2005, 06:06 PM
burr ridge illinois
Joined Oct 2003
That last one's pretty close to what I'm looking for, although it will be charging my 860s at >1C (not by much, though...)
Old Jun 03, 2005, 06:16 PM
hybris's Avatar
Houston, TX
Joined May 2003
Yes, that's why I recommend looking for one around a 800-900mA charge rate. Then it will just charge your 1300s slower.
Old Jun 04, 2005, 01:17 AM
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
You need to buy a charger like the thunderpower 425, or kokam one, that can go up to 4 cells, then buy something like a laptop powersupply, get something say 12v, 3amps, and then just slow charge your packs, and you'll be golden.
r
rroback is offline Find More Posts by rroback
Old Jun 06, 2005, 06:04 PM
burr ridge illinois
Joined Oct 2003
(The whole idea is to avoid the power supply)
Old Jun 06, 2005, 06:13 PM
Convert!
rroback's Avatar
Joined Nov 2002
well, I there is always going to be a powersupply, it just may be built into the charger or not. you're best bet is a small little unit, and just make a neat little package with it and the charger.
r
Question LiPo CHARGER HELP setotitan Micro Helis 7 Jul 20, 2007 11:18 PM
Discussion Lipo Charger Help kevin_mic Utah Flyers Organization 1 Mar 17, 2006 10:46 AM
110 Volt Lipo charger--HELP! echassin Batteries and Chargers 0 Jun 03, 2005 12:26 PM
Alert Lipo charger HELP! mentat Batteries and Chargers 2 Dec 22, 2004 08:00 AM
lipo charger help!!! kase_kopf Batteries and Chargers 1 Jun 23, 2004 02:38 PM
