Old Nov 15, 2014, 09:42 AM
funkz's Avatar
United States, NC, Cornelius
Joined Jul 2012
RG712BX (JR receiver)
Hia,
Anyone out there using this receiver?
RG712BX
http://www.jrpropo.co.jp/jpn/products/img/03597.jpg
http://static.rcgroups.net/forums/at...68-RG712BX.jpg
There a thread already on it but not much feedback regarding it use. It's said it consumes less power and doesn't require the satellite module to send telemetry.
funkz is offline Find More Posts by funkz
Old Nov 15, 2014, 08:10 PM
I'm in the inverted lift
racedouge1's Avatar
United States, CO, Golden
Joined Feb 2006
I have been useing two 731BX recievers in powered planes with no problems...But I use 631B recievers for my DLGs and I'm very happy with them. A 600 MHr battery yeilds two plus hours of flying.
racedouge1 is offline Find More Posts by racedouge1
Old Nov 16, 2014, 02:03 AM
launch low, fly high
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
(posted in the XG8 thread in addition)
The 712BX receiver seems to work nicely. The benefits are that it does not need a satellite to have downlink capability and that the current drain is lower. I got a bit of reasonable weather today to do some test flying and it appears that it translates my commands to the airplane reliably, even at my eyesight limits. It works very well for F3K once you remove the bulky plastic case.
Joe W is offline Find More Posts by Joe W
Old Nov 16, 2014, 04:00 AM
funkz's Avatar
Joined Jul 2012
I just ordered one a couple of days ago. Is reassuring to read the above line. The plastic case is around 6gr so replacing that with shrink tube will bring the weight to around 10gr for a diversity antenna and telemetry capable receiver, not bad IMO.
The other point im curious is battery consumption, it might give for sure better times than the 831B+Sat (what I currently use).
Old Nov 16, 2014, 04:35 AM
Joined Dec 2004
If you are currently using the 831, then you will be very familiar with the form factor for the 712 receiver. I have been using the 631 rx for f3k recently (used to use the 831), and I think I lost some weight by switching to the 712 as I do not need the remote anymore. BTW, I removed the plastic case and used tape to wrap the rx instead up using heat shrink. Lighter and less bulky. YMMV...
Old Nov 16, 2014, 04:43 AM
Joined Dec 2004
Just weighed the 712 rx.
The case is 6.48g. The rx without the case is 8.67g. The case weighs almost as much as the rx. I suspect that about 25% of the rx weight is the antennae...
Add: for reference, the 631 rx weighs 12.34g with the case removed on the remote satellite (satellite included on this weight). The 631 rx (with its thin plastic sheet case) weighs 9.12g without the satellite. So, I lost weight by going to the 712 rx from the 631 rx.
Last edited by Joe W; Nov 16, 2014 at 04:50 AM. Reason: included 631 weights for reference.
Old Nov 18, 2014, 11:17 PM
Just Fly it
USA, CA, Bakersfield
Joined Jul 2006
Sounds Good
Just wondering why they are not available.
Indubitably is online now Find More Posts by Indubitably
Old Nov 18, 2014, 11:58 PM
Claude Turner
claude60's Avatar
United States, CA, Visalia
I got word that JRAmericas should have them in a couple weeks. Claude
claude60 is offline Find More Posts by claude60
Old Nov 19, 2014, 10:36 AM
**coming to a town near you**
FlyingGorilla83's Avatar
United States, NM, Albuquerque
Joined Apr 2013
heck ya!! Im in!! But I wont be using the 712rx with a Shred lipo.... I already know the voltage on those, lol
FlyingGorilla83 is offline Find More Posts by FlyingGorilla83
Old Nov 19, 2014, 10:46 AM
Mickey from Orlando. Really.
Joined Nov 2004
a diversity antenna..
If it's like the other JR receivers it's a diversity receiver, not just a diversity antenna.
mnowell129 is offline Find More Posts by mnowell129
Old Nov 19, 2014, 11:05 AM
funkz's Avatar
Joined Jul 2012
sure, and i wanted to write diversity receiver but got mislead by JR's way of selling it. I guess they put the word antenna to make clear is dual(?)... anyhow, if the 831B works, then the 712BX will be even better.
Old Nov 19, 2014, 11:09 AM
Joined Nov 2004
I'm not sure why they undersell this. It's a good feature. It costs some power, but is pretty reliable.
Old Nov 19, 2014, 11:33 AM
funkz's Avatar
Joined Jul 2012
arggg forget it!
is not they undersell is that the word antenna migth be giving a "better" idea of what the system (general idea) means...
Old Nov 19, 2014, 12:36 PM
Joined Apr 2013
The fact that this Rx weighs less than the 631 with downlink capability makes it very appealing!! I will be ordering atleast a couple to test. Hope they fit in a Concept X4 ...
Discussion New JR X-Bus receiver RG712BX stefanoc2 Radios 4 Nov 18, 2014 02:22 AM
Discussion RG731BX versus RG712BX stefanoc2 Multi Task F3X 11 Nov 14, 2014 05:12 PM
Sold Item Sold Tipover Aircraft - General - Radio Equipment (FS/W) 0 Nov 02, 2014 07:32 PM
Sold NEW! OrangeRx module for JR/Turnigy, Satellite receiver, 9 channel twin port receiver MiG-3 Reno Rocket Aircraft - General - Radio Equipment (FS/W) 4 Oct 31, 2014 02:48 PM
For Sale Jr receivers -pcms ner-649s 72mhz + jr datasafe 2 ap_rpm Aircraft - General - Radio Equipment (FS/W) 1 Oct 01, 2014 11:46 AM
