Old May 26, 2014, 11:06 AM
USA, WA, Bremerton
Joined Feb 2007
Question
4.8v Servo - Step-down from 5.5v source
A flying buddy and I use YEP esc's on our heli's. These output only 5.5 volts. The Futaba S9257 tail servos operate at 4.8v only.
On another heli I run a separate 5.0v ubec which has worked ok.
If we use a step-down type regulator it will bring the voltage down to 4.7 under no load. Will this work or are we asking for problems. The unit we are considering is: http://www.western-robotics.com/STVR_hp.html
Are we being to worried about the voltages or what.
Any guidance would be appreciated.
Blade Crasher is online now Find More Posts by Blade Crasher
Old May 26, 2014, 11:39 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Use a better tail servo then.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old May 26, 2014, 11:50 AM
USA, WA, Bremerton
Joined Feb 2007
Why, when that servo has more capability than I will ever have at my age, hand-eye coordination and flying desires.
Thanks for your input though.
Old May 26, 2014, 12:01 PM
United States, TX, Leander
Joined Sep 2003
You could get away with running a serial diode to drop the voltage a little. I had to do that recently for a JR791 retract servo. I just upgraded to life packs and put the servo on a regulator. But one out of three servos still acted up. I put a diode in series with it and dropped the voltage enough to get it to straighten up.
Edwin
edwin1 is offline Find More Posts by edwin1
Old May 26, 2014, 12:42 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The only reason I suggested it is because you're looking at adding components (weight, possible failure points) to your model. If you have a servo on there which will run at 6V (any modern servo will) then why limit yourself with a servo that doesn't measure up to the rest of the system?
Also, why do you think that servo only works at 4.8V? I would investigate that as well. There's a guy here named "Bax" who runs the Futaba service stuff. You ought to PM him and ask if that servo will run on a 6V system. My guess is that it will, but you need to go straight to the horse.
Andy
Site Sponsor
Old May 26, 2014, 01:29 PM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Servos voltage sensitivity is tricky.
some are- some ain't
I have a model which came with servos intended for 5.3/5 volt output from a BEC
on 6.5 volts they really performed but some refused to operate at 6.6!
I ran rapid full excursion tests at 6.2volts and found that they overheated in 4 minutes and the motors went boom!
Being a timid soul- I won't run any of the servos which are intended for ARF 5.4 volt , at anything over an absolute 6.000 volts
maybe ona glider which cruises lazily - but never on a copter or aerobatic model which does a lot of fast servo reversing.
richard hanson is offline Find More Posts by richard hanson
Old May 26, 2014, 01:47 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
This is what i use on a T-Rex 600E with Futaba S9254 on the tail and the stock BEC. The S9254 is the "bigger brother" of the S9257.
ivanc is offline Find More Posts by ivanc
Old May 26, 2014, 04:50 PM
Joined Oct 2007
Ihave one of those plus the ALIGN 7.4 to 6 voltvoltage reg which came as a package - . anybody need one ?
never used just checked out on the bench when I was considering regulators - works fine.
Old May 26, 2014, 11:01 PM
USA, WA, Bremerton
Joined Feb 2007
Thanks again to all that posted.
Since I own the 9257 - that was the reason of sticking with 4.8. I will try to find Bax though and see if he has any different info.
Old May 27, 2014, 11:12 AM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Have you tried that servo at 5.5V, it should work. That servo it designed to run on a 4 cell Nixx pack, not 4.8V maximum. A fully charged 4 cell battery will be at least 5.6V to 5.8V.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
New Product Announcing the New RMRC 5V/12V Dual Step-Down Regulator TEAM RMRC FPV Equipment 1 Jun 16, 2014 02:22 AM
Help! Step-down 12V to 5V LawMate TM-240500 ianobre FPV Equipment 0 Apr 14, 2014 02:58 PM
Discussion Step down from 4S (16.8v) to 12v ? SpookiePower FPV Talk 2 Aug 02, 2011 04:11 PM
Discussion 12v-4.8v step down viper522 Electric Power Cars 4 Jan 09, 2011 06:12 PM
Discussion Step up / Step down 5V regulator NC1 DIY Electronics 2 Jan 25, 2006 12:05 PM
