Old Dec 01, 2013, 09:46 AM
United States, NJ, Frenchtown
Joined Mar 2003
Yippee!
1 of 2 Guanli PBYs is finished.
Pulled everything out except the foam & pushrods to the tail surfaces.
Used some Hyperion 12 mm inrunners. 5980 KV with 11.17 to 1 gearboxes and APC E 8 X 8" props.
battery is a 3 cell 1800 mahr. 2 BP Hobbie 30 amp. ESCs
HS-55s R & E only.
Weight RTF 29 oz..............thrust is 14 oz static. & about 38 mph Computer duration is 32 minutes. Total amps are 7.0
These are all indoor testing results.Amps volts rpms .
I connected a 14 vdc car battery to the ESCs to simulate a 4 cell pack. Almost pulls out of my hand vertically. I do have to speed up a little slower to save the tiny plastic gear teeth in the large plastic gear.
Finished up all the ding & repainting repairs. I like the light weight & duration.
cyclops2 is offline Find More Posts by cyclops2
Discussion DJI Phantom 1.2 vs 1.1.1 motosyndicate Multirotor Talk 24 Mar 26, 2014 12:05 AM
Discussion Guan Li PBY cyclops2 Waterplanes 0 Nov 20, 2013 01:21 PM
Discussion Finishing a Foam Plane with Fiberglass, Finishing Resin, Eze-kote, WBPU? torquenut Scale ARF/RTF 4 Nov 16, 2013 10:21 PM
Question Guanli Focke Wulf (Help needed) Krayola Power Systems 9 Oct 09, 2013 05:48 PM
