Old Nov 16, 2013, 05:49 AM
Joined Mar 2009
Build Log
OrangeRX / OpenLRS 433Mhz hack#2 : 1W TX onboard, APM 12 km telemetry & RC for $57
Hi,
I modified an OrangeRX 1 watt TX to be able to use it on the plane, and have a fully bidirectionnal 1W link for 2 x $28.45 : the RC channels and the telemetry are sent via the same system.
Detailed description and step-by-step instructions here.
And it works quite well with 232 packets lost on 100.090 (=0.2%)
flipflap is online now Find More Posts by flipflap
Old Nov 20, 2013, 09:37 AM
Finland, Vihti
Joined Mar 2010
Originally Posted by flipflap View Post
Hi,
Detailed description and step-by-step instructions to come...
While waiting for those instructions (), quick questions - using TX as RX, did you break out the channel pins by soldering to the ATMEGA328?
nicnet is offline Find More Posts by nicnet
Old Nov 20, 2013, 11:40 AM
Joined Mar 2009
I'm using just 3 connections : +, - and serial PPM out. For simplicity (and pin accessibility), the PPM out is on the same pin that is used for PPM in on the TX.
Serial PPM is then sent to APM, on which the servos are connected.
So it's very simple : two cables between APM and OLRS
-a cable for serial PPM
-a cable for telemetry data
Old Nov 20, 2013, 11:50 AM
Finland, Vihti
Joined Mar 2010
Oh yeah - of course the PPMin is a free pin.
So no RX side RSSI to APM?
Old Nov 20, 2013, 12:55 PM
Joined Mar 2009
I could output it on another accessible pin, for example on the "button" pin.
Old Nov 21, 2013, 02:47 AM
Moscow
Joined Feb 2012
Is it really 1W?
Did you check what is RFM23 power supply?
If it's 3.3V it's too far from 1W.
shuricus is offline Find More Posts by shuricus
Old Nov 21, 2013, 04:02 AM
Joined Mar 2009
Powered at 3.3v it gives 364 mW, powering the module at 5v gives about 600mW.
Old Nov 21, 2013, 06:47 AM
Moscow
Joined Feb 2012
I mean did you check how is it powered in futaba module?
Old Nov 21, 2013, 01:14 PM
Joined Mar 2009
It's 3.3V
Old Nov 21, 2013, 01:53 PM
Finland, Vihti
Joined Mar 2010
It's 3.3V
Why do the HK Futaba and JR Orange LRS 1W TXes specify that only 3.3v FTDI can be used?
I understand this for the 100mw models, with the RFM22s.
But what part of the 1W models is going to break if you apply 5v? Not the RFM23BP?
Old Nov 21, 2013, 02:54 PM
Joined Mar 2009
The RFM23BP needs 3.3V max on its communication pins.
Old Nov 21, 2013, 03:08 PM
Moscow
Joined Feb 2012
It actually works fine with 5V on communication ports in HawkEye.
But HK modules are not 1W as they declare. Much much less!
Old Nov 21, 2013, 04:08 PM
Finland, Vihti
Joined Mar 2010
So on the 1W HK modules, is the VCC to RFM23BP also 3.3?
If so, it should be easy enough to cut that track and apply 5v right? (like on your 100mw to 1W conversion?
Acknowledged that 1W in this case is at best 0.5W, likely less ...
Old Nov 21, 2013, 04:19 PM
Moscow
Joined Feb 2012
But you will need another voltage regulator for 5V.
Old Nov 21, 2013, 04:25 PM
Finland, Vihti
Joined Mar 2010
True, and also easy.
Build Log OrangeRX / OpenLRS 433Mhz hack#1 : upgrade 100 mW to 1W + Step-by-step instructions flipflap FPV Equipment 74 Nov 01, 2014 01:08 AM
Sold 433Mhz 1w UHF Openlrs TX and RX Set $99.99 cstearns Aircraft - General - Radio Equipment (FS/W) 0 Oct 17, 2013 01:58 AM
Sold Rangelink TX/RX complete set 433Mhz UHF Long range system compuatic FPV Equipment (FS/W) 2 Sep 13, 2013 12:01 PM
Sold Rangelink TX/RX complete set 433Mhz UHF Long range system compuatic FPV Equipment (FS/W) 0 Sep 05, 2013 03:44 PM
Discussion Flytron 1w OpenLRS Tx with HK OrangeRx receiver? ummagawd FPV Talk 2 Jul 20, 2013 11:22 PM
