Old May 05, 2013, 02:04 PM
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Question
Hyperion DS 095's on Airtronics RX?
When I connect a set a brand new DS 095's to my new airtronics RX ( 7 ch) they glitch sligtly. I'm wondering if the plugs are causing this. Before I cut the plugs and soilder on some airtronics plugs, I am wondering if anyone else has had this problem? I did remove the lip of the plug to be able to connect them. I've pluged other servo's to the RX w/ no problems.... After close inspection the pins on the hyperion's are different than hitec/airtronic's servo pins but not sure why the glitch-y-ness?
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old May 05, 2013, 06:17 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That should not make them glitch.
What other specific model of servos have you had plugged in, and which style of Rx is it (FHSS1 or FHSS3)?
R,
Target
target is offline Find More Posts by target
Old May 05, 2013, 06:48 PM
David Forbes's Avatar
United States, FL, Gainesville
Joined Dec 2005
The plugs on the Hyperions are universal, and if it's the 7ch Fhss1 92674 Rx you should be golden. Are you using an older 72mHz Rx?
Dave
David Forbes is offline Find More Posts by David Forbes
Old May 05, 2013, 07:02 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
The Hyperion plugs are Futaba, not universal. They have the tab on the male plastic connector which must be removed in order to insert them into a JR or "new" Airtronics socket in an Rx....
R,
Target
Old May 05, 2013, 09:05 PM
Go ahead. Meme me!
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Plugs should be fine but some of those 095's have bad pot wiring. You'll know if they react to squeezing, tapping, or wire tugging.
vespa is online now Find More Posts by vespa
Old May 06, 2013, 11:51 AM
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
R,
Target
hitec 85 futaba 3150 airtronics 761's
Old May 06, 2013, 12:03 PM
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
yes they do react to touching wires...bad pot wiring? is it a solder problem?
Old May 06, 2013, 12:05 PM
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Originally Posted by david forbes View Post
the plugs on the hyperions are universal, and if it's the 7ch fhss1 92674 rx you should be golden. Are you using an older 72mhz rx?
Dave
sd 10 g
Old May 06, 2013, 12:46 PM
Go ahead. Meme me!
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yes. Pot wires inside. Some threads and pics here on RCG. Or get replacements.
Old May 06, 2013, 12:52 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Jeremy-
How's the shaft rock on the 095's??
I absolutely LOVE the DS11's, but the DS13's seem to have a lot of shaft rock due to them having only one ball bearing. I think the 095's have two, so that should not be as much a problem?
R,
Target
Old May 06, 2013, 01:46 PM
Go ahead. Meme me!
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yes, DS13's are junk. Shaft rock on the 095 is minimal, maybe on par with 761's. The 2.3mm thread makes 3rd bearings tricky so I came up with a solution that works extremely well -- just a 6mm OD brass tube. The servo arms have a deep well that seems pretty precise at 6mm and the tube doesn't interfere with the screw. It actually makes for an unusually solid and true-running setup since it interfaces directly with the arm instead of a screw. See pics:
Old May 06, 2013, 02:08 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That is a very interesting solution... So the brass tube acts as a plain bearing inside the servo arm.
R,
Target
Old May 06, 2013, 03:37 PM
Go ahead. Meme me!
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yep. The brass-on-nylon makes a pretty nice wear surface and the load path and concentricity are possibly better than traditional screw-based solutions. It's likely the lightest possible 3rd bearing setup imaginable as well as the cheapest and easiest to install/service. The friction is slightly higher than a bearing of course, but it's very low and the good concentricity keeps the friction more consistent than other solutions.
Old May 07, 2013, 05:45 PM
harborflyer's Avatar
United States, CA, Santa Ana
Joined Jul 2010
A touch of moly grease might help with friction concerns.
Ross
harborflyer is online now Find More Posts by harborflyer
For Sale HYPERION ATLAS DS 20X SMD CORELESS DIGITAL SERVO FOR YOUR 550/600 Heli's NIB! mygsx Aircraft - Electric - Helis (FS/W) 1 May 16, 2013 03:36 AM
Sold Airtronics RX-631 / 94802 servos / Hyperion DS09 servos djensen Aircraft - General - Radio Equipment (FS/W) 2 Jan 31, 2013 09:39 AM
For Sale Two NIB Hyperion DS-095-FMD servos VH-ASC Aircraft - Sailplanes (FS/W) 0 Sep 16, 2012 11:02 PM
For Sale 4 Hyperion DS 095 FMD Servos Mark Miller Aircraft - Sailplanes (FS/W) 1 Mar 03, 2011 05:13 PM
Sold HYPERION DS 095 FMD Wing Servos Mark Miller Aircraft - Sailplanes (FS/W) 1 Feb 03, 2011 09:17 AM
