Old Apr 21, 2013, 08:55 PM
Joined Apr 2013
Blade 450 3D Power Adaptor
Hi this Is my first post as I am new to this forum.
The question that I have is can I use a 12 V x 2000amp Power Adaptor for my Blade 450 3D
It states in the manual to use a 12 V x 1800amp with my DC balancing charger and 3S Li-Po
battery.
Stret is offline Find More Posts by Stret
Old Apr 22, 2013, 09:17 AM
Just a 9116 flyer.
Rajah235's Avatar
Australia, NSW, Wollongong
Joined Dec 2012
Simple answer = yes.
Your power adaptor is capable of supplying 2 Amps so is O.K. to use.
The 1.8 Amp one stated in the manual will probably be just the minimum you should use.
eg; You could use a 100 Amp unit if you liked, because it depends on the load.
(Your charger & battery.)
Just make sure of the polarity.
Rajah235 is offline Find More Posts by Rajah235
Old Apr 22, 2013, 09:50 AM
Joined Apr 2013
polarity.
What is meant by the term (polarity).
I will try and find out by google help.
Thanks for the advice Rajah.
Old Apr 22, 2013, 09:55 AM
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
Polarity = Positive &/or Negative.
Just make sure that the plugs & sockets are the same.
eg; Centre pin is positive & outside is negative or vice versa.
If you haven't already got one, buy a cheap digital multi meter.
The Wiki > http://en.wikipedia.org/wiki/Polarity_symbols
Old Apr 22, 2013, 10:04 AM
Joined Apr 2013
I did use the adapter that I mentioned 12V x 2000amp and it did charge up the battery fine. Just was concerned if it would damage either the charger or the battery!
Old Apr 22, 2013, 10:27 AM
Just a 9116 flyer.
Rajah235's Avatar
Joined Dec 2012
As long as you don't try to charge at too high a rate, you'll be fine.
As I mentioned, you can use a 100 Amp power supply & have no problems.
It all depends on the load.
The polarity of the plug/sockets is much more important.
If they are wrong.......the magic smoke will miraculously appear.
Question Next heli after a Blade Nano CP X? Blade 300X? 450 3D? 450X? Arycon Mini Helis 15 Jun 28, 2013 11:41 PM
Discussion Blade 450 3D spools up after switching TH themoonkity 3D Electric Heli Flying 13 May 22, 2013 09:00 PM
Alert Blade 450 3d BNF NIB rpstar Atlanta Area RC 4 Mar 30, 2013 01:07 AM
Sold Blade 450 3D!!! TheBeastTamer Aircraft - Electric - Helis (FS/W) 2 Mar 27, 2013 12:32 AM
Wanted Wanted blade 450 3d Main blade Grips Blackbrair Aircraft - Electric - Helis (FS/W) 0 Feb 27, 2013 01:00 PM
