Old Feb 28, 2013, 12:19 PM
Joined Jan 2009
Functional flying wires and radio?
In planning stage of large scale (50% ) vintage design from the late 19 20's. It has a maze of wire rigging that could easily be functional. Shoud I worry about my radio install and possible radio interferance due to the rigging? I'm getting back into RC since the mid 80's and thid is my second LARGE model, this year. However, this one is for my own use and I noted on my earlier effort that 50% means that there's A LOT more room for radio placment/configuration. Am I worrying needlessly? I realize there is a vast difference between today's radios and what I'm more familiar with..
TIA
charlie
packardpursuit is offline Find More Posts by packardpursuit
Old Feb 28, 2013, 05:24 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I really don't think it will be an issue as long as the antenna (or antennae if using multiple receivers) are kept clear of the wires.
tkallev is offline Find More Posts by tkallev
Old Feb 28, 2013, 05:42 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
My gut tells me there should not be a problem if using a good high quality radio system. Of course testing will tell the true tail.
With the above said.... Spectrum / JR may have a slight advantage with being able to use multiple RX's. There are even LONG extension wires to allow you to get the satellite RX's a long ways away from each other to maximize reception.
I switched from JR to Hitec just recently. No issues with JR except price.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 28, 2013, 05:51 PM
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
I agree that the 2.4 systems are bar none and have drasticaly reduced interference.
Sullivan also makes a kevlar flying wire that is nonmetalic and is said to not streatch like stainless steel cable.
rjstrickjr is offline Find More Posts by rjstrickjr
Old Feb 28, 2013, 08:23 PM
Joined Jan 2009
Perhaps I should have added that the control system will, in all probability be very scale like too, in that all the control cables will be exposed. I'll do some searches for Sullivan kevlar "wires". Anyone ever use Spider Wire for rigging and controls???
charlie
Old Mar 01, 2013, 03:55 PM
United States, FL, North Port
Joined Mar 2004
sullivan's kevlar pull-pull sucks, the cord always breaks
invertmast is offline Find More Posts by invertmast
Old Mar 02, 2013, 11:38 PM
Big Nuts 181's Avatar
Joined Jul 2004
if your using the proper flat sectioned flying wires without play in the hardware you will be fine.
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Mar 03, 2013, 12:04 PM
Joined Jan 2009
So, if I use round music wire and flexible cable , 1/2 the diameter as per the real aircraft, my radio won't work?
The design I'm working on has the pilot stting outside in the elements. At half scale, modeled on myself (average build, 5'-11, fat head, etc.), that's a huge pilot figure! I was thinking his foam torso could be made quite cavernous', for batteries and servos (ballast forward!). Operating scale controls with a "robot pilot' arm and legs would be quite feasable, I'm thinking.
Having servo move one/both legs on functioning rudder bar seems doable. However getting side to side movement of stick/ailerons has not revealed itself to me ...yet.
Anyone know who makes functionng scale like turnbuckles?
Old Mar 03, 2013, 12:15 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Both of the following links make very nice turnbuckles and other accessories. I use products from both.
http://www.proctor-enterprises.com/p...e/hardware.htm
http://vogelsang-aeroscale.com/tools.html
ace4rc is offline Find More Posts by ace4rc
Old Mar 03, 2013, 01:43 PM
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Now,now Packard,settle down....My 1/3 scale Sopwith pup has 86feet of cable on it.-and I still fly 72 MHZ. Zenoah G-62,and a belt reduction drive system,brass bushings in plastic wheels on steel axles.
It is NOT an accident waiting to happen.
Go have yourself a ball.
DuBro has turn buckles also.
epoxyearl is offline Find More Posts by epoxyearl
Old Mar 03, 2013, 02:15 PM
Joined Jan 2009
just having a bit of fun Earl. Wasn't trying to ruffle any feathers. Just thought the flat vs round wire implication a bit funny. LOL
Besides, I did use "emoticons".
Old Mar 03, 2013, 02:23 PM
epoxyearl's Avatar
Joined Oct 2011
I know...lol.
It hasn't been an issue for some time now, has interference.
I think that once we learn to fly better, we have a lot less "radio" problems.
Old Mar 03, 2013, 02:33 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Earl is that fly better or build better?
Old Mar 03, 2013, 04:40 PM
epoxyearl's Avatar
Joined Oct 2011
No- I think I meant "fly"...I haven't crashed in years, so we MUST have better radios, now.lol.
Old Mar 03, 2013, 05:25 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
That was meant to be humorous. Haven't crashed in years myself so maybe a little bit of both for me.
Discussion Will RC Wattmeters Function With Just A Red Wire Thruput? itsme2 Power Systems 5 Dec 20, 2012 04:35 AM
Question vision delux wire colour functions? rccunuk FPV Talk 1 Aug 21, 2011 11:44 PM
Discussion What is the function of the green wire between the RX2435 and the UFLYS ESC ??? ZamBeZi Micro Helis 2 Apr 04, 2011 11:46 PM
Does flying near wire/metal fencing increase radio range? RPatrick Electric Plane Talk 10 Feb 02, 2002 09:08 PM
